Schematic hp pavilion dv3 discrete ls-4735p caps lock led board schematic
hp pavilion dv3 discrete_ls-4735p caps lock led board schematic
compal ls-4735p caps lock led board.pdf
BrandCompal Electronics, Inc.
Project CodeLS-4735P
Board NumberLS-4735P
Revision0.2
DateThursday, October 23, 2008
Document NumberLS-4735P
This Compal Electronics LS-4735P document, revision 0.2 dated October 23, 2008, is a schematic for a Caps Lock LED board. The board includes a PCB component labeled JP1, an FPC connector, and an LED component D1, model HT-260BP_2P. The design also incorporates a resistor R1 with a value of 1.2K ohms in a 0402 package. The document is proprietary to Compal Electronics, Inc.
Q: What is the document number and revision for this board?
A: The document number is LS-4735P, and the revision is 0.2.
Q: What LED component is used on this board?
A: The LED component is D1, model HT-260BP_2P.
Q: What is the value of resistor R1?
A: Resistor R1 is 1.2K ohms in a 0402 package.
  • HP Pavilion DV3=1=Discrete_LS-4735P CAPS Lock LED Board.zip
