Schematic hp pavilion dv4000 leopard2 rev1 schematic
hp pavilion dv4000 leopard2_rev1 schematic
hp pavilion dv4000=1=leopard2_rev1.pdf
BrandWistron Corporation
ModelLeopard2
Project Code91.4C701.001
Board Number48.4C701.011
Revision05202
DateMonday, July 11, 2005
Document NumberA3147
CPU PlatformDothan Mobile CPU
CPU SocketHost BUS 400/533MHz
PCH / SouthbridgeICH6-M
GPU TypeATI M26
Graphics ArchitecturePEG
EC / KBCG768
EC/KBC PackageD4Mb(512kB)
Audio CodecAD1981B
BIOS / SPI FlashLPC Bus Flash Rom
Charging ICMAX8725
Charger ArchitectureMAXIM CHARGER
Power IC(s)MAX1907, MAX8743, TPS5130, TPS2220, TPS2231
RAM TypeHY5DS573222F-28
RAM ArchitectureDDR-SDRAM
Card Reader ICNS97551
LAN ICRTL8100C
WiFi / WLAN IC802.11a/b/g Mini-PCI
USB Hub ICPCI 7411
The Wistron Leopard2 motherboard, documented under project code 91.4C701.001 and board number 48.4C701.011, is built around the Dothan Mobile CPU platform with a 400/533MHz Host Bus. The platform utilizes an ICH6-M southbridge and an ATI M26 GPU with a PEG interface. System memory consists of HY5DS573222F-28 DDR-SDRAM modules. The embedded controller is a G768 with 4Mb (512kB) internal flash, and the system BIOS is stored on an LPC Bus Flash ROM. Audio is handled by an AD1981B AC'97 codec, while networking is provided by an RTL8100C 10/100 LAN controller and an 802.11a/b/g Mini-PCI wireless module. Power management is managed by a MAX8725 charger and a suite of DC/DC converters including the MAX1907, MAX8743, and TPS5130. Peripheral connectivity includes a PCI 7411 CardBus/1394 controller and an NS97551 card reader.
Q: What is the project code and board number for this motherboard?
A: The project code is 91.4C701.001 and the PCB part number is 48.4C701.011.
A: The embedded controller is a G768 with 4Mb (512kB) of internal flash memory.
Q: What type of BIOS flash is used?
A: The system uses an LPC Bus Flash ROM for BIOS storage.
Q: What is the charging IC and charger architecture?
A: The charging IC is a MAX8725, and the architecture is a MAXIM CHARGER design.
  • HP Pavilion DV4000=1=leopard2_Rev1.zip
