hp pavilion dv7 amd_jbk00_la-4092p_rev0.4 schematic
hp pavilion dv7=1=amd_jbk00_la-4092p_rev0.4.pdf
This Compal LA-4092P Rev 0.4 schematic, dated 2008-02-20, details a motherboard designed for a Mobile AMD S1G2 CPU platform. The core logic is built around the ATI RX781 and ATI SB700 southbridge, supporting an AMD UMA/DISCRETE 17" graphics architecture with a discrete ATI M82-S GPU. The system utilizes DDR2 memory in a dual-channel configuration via two SO-DIMM slots. The embedded controller is a KB926, and the audio subsystem is managed by a 92HD71B7 codec. Networking is provided by a Realtek RTL8111C Gigabit LAN controller. The schematic also includes a JMB380 card reader controller, an ADM1032ARMZ thermal sensor, and an SPI ROM for EC firmware storage.
A: The board number is LA-4092P, and the revision is 0.4.
A: The embedded controller is a KB926.
Q: What is the graphics architecture of this motherboard?
A: The graphics architecture is AMD UMA/DISCRETE 17", with a discrete ATI M82-S GPU.
A: It supports DDR2 memory in a dual-channel configuration via two SO-DIMM slots.
| Board Number | LA-4092P |
| Revision | 0.4 |
| Date | 2008-02-20 |
| CPU Platform | Mobile AMD S1G2 CPU |
| PCH / Southbridge | ATI SB700 |
| GPU Type | ATI M82-S |
| Graphics Architecture | AMD UMA/DISCRETE 17" |
| EC / KBC | KB926 |
| Audio Codec | 92HD71B7 |
| LAN IC | RTL8111C |
| Card Reader IC | JMB380 |
| Thermal Sensor | ADM1032ARMZ |
| RAM Type | DDR2 |
| RAM Quantity / Slots | DDR2-SO-DIMM X2 |
| Charging IC | TPA6020A2 |
| Power IC(s) | TPA3007D |
| WiFi / WLAN IC | Mini-Card*2 |
| HDMI Level Shifter | SLG8SP626 |
| USB Hub IC | USB2.0 X12 |
| EC Flash / ROM | SPI ROM |
LA-4092P
Mobile AMD S1G2 CPU
ATI SB700
ATI M82-S
KB926
92HD71B7
RTL8111C
JMB380
ADM1032ARMZ
DDR2
TPA6020A2
TPA3007D
Mini-Card*2
SLG8SP626
USB2.0 X12
LA-4092P
Mobile AMD S1G2 CPU
ATI SB700
ATI M82-S
KB926
92HD71B7
RTL8111C
JMB380
ADM1032ARMZ
DDR2
TPA6020A2
TPA3007D
Mini-Card*2
SLG8SP626
USB2.0 X12
