Technical Support HP ProBook 450 G1
pankajbiyani
I HAVE A PROBLEM IN LAPTOP BATTERY MODE NOT TURNING ON BUT ADAPTER MODE LAPTOP START THEN BATTERY CHARGING % NOT INCREASE ,
I CHECK DONE,BATTERY DRIVE MOSFET AND CHARGING IC REPLACE BUT PROBLEM NOT SOLVE,
  • HP ProBook 450 G1 Wistron S-Series Shark Bay 12241-1 48.4YW05.011 Schematics.pdf
Check the adapter.
Check the detect adapter path from the jack to the EC. Usually there is a 100 ohm resistance in the path that burns and the ohm increases.
Check the charging IC and EC IC.
Prozon
Did you check voltage in regn pin in charging ic is your boost voltage available.
pankajbiyani
Hello Sir,
I done Shift PR4403 Down PR4406 And PR4402 Removed, Then battery Charging % increasing and battery mode laptop work,
