Schematic hp probook 6540b ls-4895p serial board rev 0.5 schematic
BrandCompal
Document NumberLS-4895P
Revision0.5
DateMonday, July 06, 2009
Board NumberLS-4895P
This Compal Electronics LS-4895P schematic, revision 0.5, dated July 6, 2009, is a proprietary engineering document. The document covers a Switch Board design, including a Serial Port connector and a MAX3243ECUI+T RS-232 transceiver in a TSSOP-28 package. The board utilizes various passive components, including 330pF, 0.1uF, and 0.047uF capacitors, along with 10K ohm and 47 ohm resistors. The design also incorporates a SSM3K7002F MOSFET and specific connectors such as the ACES_50228-01271-001 and SUYIN_070905GS009G225ZR. The schematic is marked as confidential and proprietary to Compal Electronics, Inc.
Q: What is the document number and revision of this schematic?
A: The document number is LS-4895P, revision 0.5.
Q: What is the date of this schematic?
A: The schematic is dated Monday, July 06, 2009.
Q: What RS-232 transceiver IC is used on this board?
A: The board uses a MAX3243ECUI+T in a TSSOP-28 package.
  • HP_PROBOOK_6540B=LS-4895P_Serial_Board_Rev_0.5_DR-BIOS.COM.zip
