hp stream 14-ax series quanta 0p9 da0p9mb16d0
The Quanta OP9 motherboard is built on the Intel Brasswell platform, utilizing a BGA1170 package CPU. The system memory architecture consists of DDR3L memory down with four onboard chips. The embedded controller is an IT8987, and the audio subsystem is managed by a Realtek ALC3227 codec. For storage and expansion, the board supports eMMC 4.5, an NGFF M.2 SSD via SATA, and an NGFF M.2 slot for WLAN. A Realtek RTS5239-GR card reader IC is present for SD card support. The platform integrates USB 3.0 and USB 2.0 ports, an HDMI port, and an eDP panel interface. The block diagram indicates a Fast SPI interface for BIOS/SPI flash, though the exact flash model is not specified in the provided source.
Q: What is the project code and board revision for this Quanta motherboard?
A: The project code is OP9, and the document number is 1A137 with revision 1A.
Q: What EC/KBC controller is used on the Quanta OP9?
A: The embedded controller is an IT8987.
A: The audio codec is a Realtek ALC3227.
Q: What type of memory architecture does the Quanta OP9 use?
A: The board uses DDR3L memory down architecture with four onboard memory chips.
| Brand | Quanta |
| Model | OP9 |
| Motherboard Manufacturer | Quanta Computer Inc. |
| Project Code | OP9 |
| Document Number | 1A137 |
| Revision | 1A |
| Date | Tuesday, June 07, 2016 |
| CPU Platform | Intel Brasswell |
| CPU Package | BGA1170 |
| EC / KBC | IT8987 |
| Audio Codec | ALC3227 |
| RAM Type | DDR3L |
| RAM Architecture | Memory down, 4 pcs |
| Card Reader IC | RTS5239-GR |
| WiFi / WLAN IC | WLAN |
