hp touchsmart 310 quanta zn2_reva schematic
hp touchsmart 310=1=quanta zn2_reva.pdf
This Quanta ZN2 project motherboard, dated March 16, 2010, is built around the Intel Lynnfield processor in an LGA1156 socket paired with the Ibex Peak PCH. Graphics are handled by an MXM Type-A module. The system utilizes an ITE8512 LQFP128 EC/KBC with an 8Mb SPI flash for its firmware. The main BIOS is stored on a separate SPI flash ROM. Audio is provided by a Realtek ALC269 codec, and networking by a Realtek RTL8111DL LAN controller. Memory architecture consists of dual-channel DDR3 800/1066/1333MHz across two SO-DIMM slots. The board features a JMicron JMB385 card reader and uses a CK505 clock generator. Power management is handled by a combination of controllers including NCP5392, NCP1589A, TPS51116, ISL6314, and NCP5380, with an NCP1587 charging IC.
A: The motherboard uses an ITE8512 EC/KBC in an LQFP128 package, with its firmware stored on a dedicated 8Mb SPI flash.
A: The board supports dual-channel DDR3 memory at 800/1066/1333MHz and 1.5V, using two SO-DIMM slots (SO-DIMM0 and SO-DIMM1).
Q: What LAN and audio controllers are present?
A: The LAN controller is a Realtek RTL8111DL, and the audio codec is a Realtek ALC269 in a QLQFP48 package.
| Project Code | ZN2 |
| Date | Tuesday, March 16, 2010 |
| CPU Platform | Lynnfield/64-bit/45nm LGA1156 (37.5x37.5mm) |
| PCH / Southbridge | Ibex Peak |
| GPU Type | MXM CNN Mobile PCI-E Module (Graphics) TYPE-A (314 pin) |
| EC / KBC | ITE8512 LQFP128 |
| Audio Codec | ALC269 QLQFP48 |
| BIOS / SPI Flash | SPI FLASH ROM |
| EC Flash / ROM | 8Mb SPI |
| LAN IC | Realtek RTL8111DL |
| Card Reader IC | JMICRO JMB385 |
| RAM Type | DDR3 |
| RAM Architecture | Dual channel DDR3 800/1066/1333MHz 1.5V |
| RAM Quantity / Slots | SO-DIMM0, SO-DIMM1 |
| Charging IC | NCP1587 |
| Power IC(s) | NCP5392, NCP1589A, TPS51116, ISL6314, NCP5380 |
| Clock Generator | CK505 |
ZN2
ITE8512 LQFP128
ALC269 QLQFP48
8MB SPI
BIOS / EC Flash
RTL8111DL
JMICRO JMB385
DDR3
NCP1587
ISL6314
NCP1589A
NCP5380
NCP5392
TPS51116
CK505
Clock Generator
ZN2
ITE8512 LQFP128
ALC269 QLQFP48
8MB SPI
BIOS / EC Flash
RTL8111DL
JMICRO JMB385
DDR3
NCP1587
ISL6314
NCP1589A
NCP5380
NCP5392
TPS51116
CK505
Clock Generator
