hp vb1.0 ati m76m ddr3 pv build a02 0516 1
This Inventec PC3601 motherboard, revision A01 dated 13-Feb-2007, is built around the ATI M76M graphics architecture with DDR3P video RAM. The document number is PC3601114A3CSVB1.0_ATI_M76M. Power management is handled by a SEMTECH_SC471A_MLPQ_16P charging IC, alongside TI_TPS51117_QFN_14P, ANPEC_APL5913_KAC_TRL_SOP_8P, TEC_AZ431LANTR_E1_SOT23_3P, and MAX_MAX1673_SOP_8P power ICs. The board includes dedicated video RAM sections and an MXM connector, with core voltage adjustable via resistor changes for M76 +V1.1 support.
A: The board number is PC3601, revision A01.
Q: What graphics architecture is used on this motherboard?
A: The graphics architecture is ATI M76M.
Q: What type of video memory is used on this motherboard?
A: The video memory type is DDR3P.
A: The charging IC is SEMTECH_SC471A_MLPQ_16P.
| Brand | Inventec |
| Motherboard Manufacturer | Inventec |
| Project Code | PC3601 |
| Board Number | PC3601 |
| Revision | A01 |
| Date | 13-Feb-2007 |
| Document Number | PC3601114A3CSVB1.0_ATI_M76M |
| GPU Type | ATI M76M |
| Graphics Architecture | ATI M76M |
| RAM Type | DDR3P |
| RAM Architecture | Video RAM |
| Charging IC | SEMTECH_SC471A_MLPQ_16P |
| Power IC(s) | TI_TPS51117_QFN_14P, ANPEC_APL5913_KAC_TRL_SOP_8P, TEC_AZ431LANTR_E1_SOT23_3P, MAX_MAX1673_SOP_8P |
