HP ZBook 17 G3 LA-C381P LA-C382P Schematic
This Compal LA-C382P Rev 0.2 motherboard, model APW50, is built around the Intel Skylake-H 4+4e processor with SPT-H PCH, supporting a discrete GPU via an MXM 3.0 PEG x16 slot. The system firmware is stored on a W25Q128FVSIQ SPI flash, while the EC firmware resides on a separate W25Q64FVSSIQ flash. The embedded controller is an NPCE586HA0MX, programmable through eSPI. Memory architecture consists of two DDR4 SODIMM slots operating in dual-channel mode. Type-C PD charging is managed by a TPS65982 controller, with a TPS2546RTER for USB charging. The audio subsystem is driven by an ALC3268 codec, and networking is provided by an WGI219LM LAN IC. Display connectivity includes an IT6515FN HDMI level shifter, and thermal monitoring is handled by an NCT7718W sensor.
A: The BIOS SPI flash is a Winbond W25Q128FVSIQ.
A: Yes, the NPCE586HA0MX EC is programmable via eSPI.
Q: What is the EC flash IC model?
A: The EC flash is a Winbond W25Q64FVSSIQ.
Q: What charging architecture does this motherboard use?
A: Type-C PD charging is implemented using a TPS65982 controller.
| Model | APW50 |
| Board Number | LA-C382P |
| Revision | 0.2 |
| Date | 2016/03/08 |
| CPU Platform | Intel Skylake-H 4+4e Processor with SPT-H_PCH |
| PCH / Southbridge | Intel SPT-H_PCH |
| GPU Type | Skylake-H 4+2 (DIS) |
| Graphics Architecture | MXM 3.0 Conn PEG x16 |
| EC / KBC | NPCE586HA0MX |
| EC/KBC Programmable | eSPI |
| Audio Codec | ALC3268 |
| BIOS / SPI Flash | W25Q128FVSIQ |
| BIOS Flash Capacity | 128 Mbit (16 MB) |
| EC Flash / ROM | W25Q64FVSSIQ |
| Charging IC | TPS65982 |
| Charger Architecture | Type-C PD |
| Power IC(s) | TPS2546RTER |
| RAM Type | DDR4 SODIMM |
| RAM Architecture | Dual Channel (Ch A, Ch B) |
| Card Reader IC | RTS5258S |
| LAN IC | WGI219LM |
| WiFi / WLAN IC | Intel Alpine Ridge 4C(Host) |
| HDMI Level Shifter | IT6515FN |
| Thermal Sensor | NCT7718W |
LA-C382P
Skylake-H 4+2 (DIS)
NPCE586HA0MX
ALC3268
W25Q64FVSSIQ
BIOS / EC Flash
TPS65982
TPS2546RTER
DDR4 SODIMM
RTS5258S
WGI219LM
IT6515FN
NCT7718W
LA-C382P
Skylake-H 4+2 (DIS)
NPCE586HA0MX
ALC3268
W25Q64FVSSIQ
BIOS / EC Flash
TPS65982
TPS2546RTER
DDR4 SODIMM
RTS5258S
WGI219LM
IT6515FN
NCT7718W
