ibm r61 r61i t61 t61i waikiki-1.1 sit silk bot 070201 boardview 1
This motherboard, identified as the ASD 42W9259, is an 8-layer PCB design. The schematic is at revision 1.0 (S1.1) with a date of 200X/MM/DD. The board layout includes a SILKSCREEN_BOTC layer and a TITLELAYER. The design incorporates numerous components including resistors, capacitors, inductors, diodes, transistors, and integrated circuits, with specific reference designators such as U7011, U7012, U7013, U7003, U7016, and U1 through U66. The board also features multiple connectors (J13, J14, J23), fuses (F1, F2, F4, F6, FL1, FL3, FL4, FL5, FL7, FL9, FL10, FL11, FL13, FL14, FL15, FL18, FL19), and test points (TP16, TP17, TP18, TP19, TP133, TP134, TP135). The design includes a crystal oscillator (Y3) and a varistor (VR1).
A: The board number is 42W9259, and the revision is 1.0 (S1.1).
Q: How many layers does this PCB have?
A: This is an 8-layer PCB design.
Q: What is the date of the schematic?
A: The schematic date is 200X/MM/DD.
| Brand | ASD |
| Board Number | 42W9259 |
| Revision | 1.0 (S1.1) |
| Date | 200X/MM/DD |
| PCB Layers | 8 LAYER(S) |
