Schematic ibm thankpad l410 quanta r410 schematic schematic
ibm thankpad l410 quanta r410 schematic 1
BrandQuanta Computer Inc.
ModelG-Note Montevina
Motherboard ManufacturerQuanta Computer Inc.
Document Number1122334455667788AABBCCDD
Revision1A
DateThursday, September 03, 2009
CPU PlatformPenryn 478P (uPGA)/35W
GPU TypeGL40/GM45
Graphics ArchitectureCantiga
EC / KBCIT8502E/JX
EC/KBC PackageITE
Audio CodecALC269Q
BIOS / SPI FlashSPI EEPROM (ITPM)
Charging ICISL88731A
Charger ArchitectureSYSTEM CHARGER
Power IC(s)ISL6266A, RT8204, TPS51116, ISL6237
RAM TypeDDRIII
RAM ArchitectureDDRIII 800/1066 MT/s
RAM Quantity / Slots2
Card Reader ICJMB385
LAN ICRTL8111DL/RTL8103EL
WiFi / WLAN ICWLAN/WiMAX
Thermal SensorCPU THERMAL SENSOR
Clock GeneratorSLG8SP568/ICS9LPRS393 (QFN68)
G-SensorLIS244ALTR
TPMDiscrete TPM
The Quanta Computer Inc. G-Note Montevina motherboard, document number 1122334455667788AABBCCDD revision 1A dated September 3, 2009, is built around the Intel Penryn 478P (uPGA)/35W CPU platform with a Cantiga northbridge (GL40/GM45 GPU) and ICH-9M southbridge. The system employs an IT8502E/JX EC/KBC from ITE and an ALC269Q audio codec. BIOS storage is handled by an SPI EEPROM (ITPM). Power management includes an ISL88731A system charger, an ISL6266A CPU core regulator, an RT8204 for VCCP +1.8V and GMCH 1.05V, a TPS51116 DDR III regulator, and an ISL6237 system power controller. Memory configuration consists of two DDRIII SODIMM slots supporting DDRIII 800/1066 MT/s. The board integrates a JMB385 card reader controller, an RTL8111DL/RTL8103EL LAN IC, and a WLAN/WiMAX module. Clock generation is provided by an SLG8SP568/ICS9LPRS393 (QFN68) clock generator, and a discrete TPM is present.
A: The motherboard uses an IT8502E/JX EC/KBC from ITE.
Q: What BIOS flash type is used?
A: The BIOS is stored on an SPI EEPROM (ITPM).
A: The system uses an ISL88731A system charger.
A: The board supports two DDRIII SODIMM slots with DDRIII 800/1066 MT/s memory.
Q: What LAN IC is integrated?
A: The LAN controller is an RTL8111DL/RTL8103EL.
Technical data
  • IBM ThankPad L410=1=Quanta R410_Schematic.zip
