ibm w500 cor5d-9 ver8.01 for sovp3 schematic 1
This Lenovo Coronado-5SOVP3 motherboard, board number 43Y7016 revision 8.0 dated July 4, 2008, is built on the Cantiga CPU platform with an ICH9-M southbridge. Graphics are handled by the M86GL-M GPU. The system uses DDR3 SODIMM memory across two channels. The embedded controller is a Renesas H8S/2116B. Audio is provided by a Conexant CX20561 codec. Networking is managed by a Boazman LAN IC. The board includes a Cardbus controller for card reader functionality, a G-Sensor for thermal monitoring, and a dedicated battery charger with a charge selector architecture. A PMH7 super I/O and an EEPROM/SMBUS switch for TPM are also present.
Q: What is the board number and revision for this Lenovo motherboard?
A: The board number is 43Y7016, revision 8.0, dated July 4, 2008.
A: The embedded controller is a Renesas H8S/2116B.
A: The audio codec is a Conexant CX20561.
A: This motherboard supports DDR3 SODIMM memory across two channels.
| Brand | Lenovo |
| Project Code | Coronado-5SOVP3 |
| Board Number | 43Y7016 |
| Revision | 8.0 |
| Date | 07/04/2008 |
| CPU Platform | Cantiga |
| PCH / Southbridge | ICH9-M |
| GPU Type | M86GL-M |
| EC / KBC | H8S/2116B |
| Audio Codec | CX20561 |
| RAM Type | DDR3 |
| RAM Architecture | SODIMM |
| LAN IC | Boazman |
| Card Reader IC | Cardbus Controller |
| Thermal Sensor | G-Sensor |
| Charging IC | Battery Charger |
| Charger Architecture | Charge Selector |
| Super I/O | PMH7 |
| TPM | EEPROM/SMBUS SW/TPM |
