ibm x40 wistron s note-3 04212-sc-final schematic 1
This Wistron Corporation motherboard, documented under number A3175 revision S Note-3 dated June 1, 2005, is built around the Intel Dothan LV/ULV processor on Socket 478 with the Intel Alviso-GM integrated graphics and Intel ICH6-M southbridge. The system memory consists of unbuffered DDR2 400/533 across two 200-pin DDR SODIMM sockets. The BIOS is stored on an SST-49LF008FWH flash IC. Embedded controller functions are handled by the H8S/2161B KBC. Audio is provided by the AD1981B AC97 codec with a MAX9750 amplifier, while networking includes the Broadcom BCM5751A LAN controller and 802.11a/b/g wireless. Power management is managed by a suite of ICs including the MAX197
| Document Number | A3175 |
| Revision | S Note-3 |
| Date | Wednesday, June 01, 2005 |
| CPU Platform | Intel Dothan LV/ULV |
| CPU Socket | Socket 478 |
| PCH / Southbridge | Intel ICH6-M |
| GPU Type | Intel Alviso-GM |
| Graphics Architecture | Integrated Graphics |
| EC / KBC | H8S/2161B |
| Audio Codec | AD1981B |
| BIOS / SPI Flash | SST-49LF008FWH |
| Charging IC | MAX1870C |
| Charger Architecture | Battery Charger/Selector |
| Power IC(s) | MAX1977, MAX1907, MAX1540, MAX1993, LP2997MRX |
| RAM Type | DDR2 400/533 |
| RAM Architecture | Unbuffered |
| RAM Quantity / Slots | 2 x 200-PIN DDR SODIMM |
| Card Reader IC | RICOH R5C5811 |
| USB Hub IC | SMSC USB20H04 |
| LAN IC | Broadcom BCM5751A |
| WiFi / WLAN IC | 802.11a/b/g |
| Super I/O | PC87392NS |
| Thermal Sensor | LM263S, LM75A |
| Clock Generator | CK-410M |
| Cardbus Controller | RICOH R5C5811 |
| PCMCIA Controller | RICOH R5C5811 |
| RS232 Transceiver | MAX3243 |
| Fingerprint Sensor | Finger Print |
| G-Sensor | G-Sensor |
| Keyboard Light | MAX1989 |
| Audio Amplifier | MAX9750 |
| USB Power Switch | TPS2205 |
| EEPROM | ATMEL AT24C256, AT24RF08CN |
| FIR Transceiver | TFDU6102 |
| SATA to PATA Bridge | SATA to PATA |
| Voltage Regulator | MAX1977, MAX1907, MAX1540, MAX1993, LP2997MRX |
Intel Dothan LV/ULV
ICH6-M
Intel Alviso-GM
Integrated Graphics
H8S/2161B
AD1981B
MAX1870C
LP2997MRX
MAX1540
MAX1907
MAX1977
MAX1993
DDR2 (400/533)
RICOH R5C5811
SMSC USB20H04
BROADCOM BCM5751A
802.11A/B/G
PC87392NS
Super I/O
LM263S
LM75A
CK-410M+
Clock Generator
Intel Dothan LV/ULV
ICH6-M
Intel Alviso-GM
Integrated Graphics
H8S/2161B
AD1981B
MAX1870C
LP2997MRX
MAX1540
MAX1907
MAX1977
MAX1993
DDR2 (400/533)
RICOH R5C5811
SMSC USB20H04
BROADCOM BCM5751A
802.11A/B/G
PC87392NS
Super I/O
LM263S
LM75A
CK-410M+
Clock Generator
