Technical Support imac 21.5 2017 gpu disable
user50857
Valentin
hello!
i have a imac 21.5 2017 with gpu problems.
do you know any way to disable the gpu (as we can do with 2011 macbook pro)
Tara Laptops
Tara laptops
reball the GPU. When company has used gpu means it is a necessity. We should try to solve the problem. Without gpu the performance will suffer a lot. Well this is my sugetion
user50857
Valentin
the GPU had a problem since bying but the client can not go to apple for different reasons. so better to remove GPU and use it as a normal computer or throw it in trash?
the client knows that he can not work on heavy programs after this process
As far as I know there is no way to do this. The best way is to replace or reball the chip
