How to Remove Dell Laptop Bios Password
Dell laptop has different series, and each of them usually has a different type of password. For example, removing Bios password of Inspiron series of Dell is different from removing Bios password of the Latitude series of Dell, and there are different types of passwords as well and removing...dr-bios.com
I did as you said but he said wrong passwordpassword : vlk8qRwfZHcC3160
* for some Dell codes press Ctrl-Enter, not Enter, when entering code into the BIOS
Yes, I also tried with the external keyboard, I write the whole password correctly, but it says wrong passwordpassword is correct !
notice uppercase and lowercase words and numbers
try with external keyboard too
Thank you for your help, but we are 4 people here, we all applied what they said to the letter, but it gives an error, is there another solution?vlk8qRwfZHcC3160
lowercase v
lowercase l
lowercase k
number 8
lowercase q
uppercase R
lowercase w
lowercase f
uppercase Z
uppercase H
lowercase c
uppercase C
number 3
number 1
number 6
number 0
Thanks it worked
Hello, my password process has been solved with this bios file, but there is a problem right now, I can't activate it from Wifi and lan bios, USB is not active, I say activate it from bios and save it, when I enter the bios again, the setting returns to the beginning (I changed the bios battery, it is intact)very good
No, the date and time are correct, Windows doesn't even see the flash memory to install it, even though I activate it from bios, USB, Wifi, and ethernet biostan, it does not register, it goes back to the old state, I think it can't be changed without the administrator password, I'm trying to put a password, it constantly gives an error when setting a password, if there is another working bios file from you.this problem is related to windows
not bios
and also you should make correct time and date
Thank you, my problem was solved when I wrote both with Ec bios
