lenovo 14002 c640 c461 c466l c467a ls3694p audio schematic 1
This Compal Electronics, Inc. document, LS-3694P Rev 0.1, dated 2007-02-15, is an Audio Sub board schematic. The document is classified as Compal Secret Data and is the proprietary property of Compal Electronics, Inc. The schematic includes an Audio/Mic Jack with signals such as EXT_MIC_L-2, JACK_PLUG_MIC, PL-OUT, PR-OUT, and AUD_VREF. The PCB is identified as ZHZ LS-3694P REV0.1 Audio SUB/B. The board features components including capacitors C1, C2, C3, C4 (470pF_0402_50V), resistors R1 (3K_0402_5%), R3 (950_0402_5%), ferrite beads L1, L2, L3 (FBMA-L11-160808-700LMT), and connectors JP1 (ACES_88021-1271L), JP2, JP3 (SINGA_2 SJ-S351-01). The document also references a related USB board schematic, LS-3693P.
Q: What is the document number and revision of this schematic?
A: The document number is LS-3694P, revision 0.1.
Q: What is the PCB identifier for this board?
A: The PCB is identified as ZHZ LS-3694P REV0.1 Audio SUB/B.
Q: What type of audio jack is used on this board?
A: The schematic includes an Audio/Mic Jack with signals for EXT MIC, HEADPHONE, and MIC IN.
| Document Number | LS-3694P |
| Revision | 0.1 |
| Date | 2007-02-15 |
| PCB Number | LS-3694P |
| Schematic Number | LS-3694P |
| Board Number | LS-3694P |
