Lenovo AIO 3-22ADA6 LA-K901P Rev 1.0 Schematic
This Compal LS-K882P Power Button Board schematic, document number LS-E882P revision 0.1, dated 2020-12-24, is a sub-board designed for power button functionality. The PCB is identified as ZZZPCB LS-K882P DA4002ZR010. The board includes a power button switch (SW1), a white LED indicator (LED1, model T1361DND-30P00215), and an ESD protection diode (D1, model PESD5V0U2BT in SOT-23-3 package). Power input is provided via +5VALW_S5 rail. The board is classified as Compal Secret Data and is a proprietary design of Compal Electronics, Inc.
Q: What is the board number and revision of this power button board?
A: The board number is LS-E882P, revision 0.1.
Q: What is the PCB identifier for this board?
A: The PCB identifier is ZZZPCB LS-K882P DA4002ZR010.
Q: What type of LED is used for the power indicator?
A: The power indicator LED is model T1361DND-30P00215, a cold white LED.
This Compal LA-K901P revision 0.1 motherboard is built around an AMD FP5 APU with DDR4 memory support, utilizing two DDR4-SO-DIMM banks. The platform integrates an AMD APU (FP5 Type2) with a lidless BGA package featuring a 0.64mm ball pitch, 1140 pins, and dimensions of 25mm x 35mm, rated at 15W with a maximum frequency of 2400 MHz. The system is managed by an Nuvoton NCT6686DL EC/KBC, which is supported by a dedicated W25X20CLSNIG 2Mb EC flash ROM. The main BIOS SPI flash is a W25Q128FWSIQ 16MB IC. Audio processing is handled by a Realtek ALC233 codec, while networking is provided by a Realtek RTL8111G/H LAN controller. A Realtek RTS5140 card reader and a GL852 USB 2.0 hub are also present. The HDMI output is managed by a RTD2136Ne level shifter, and the charging circuit utilizes a TI 3110 IC.
A: The main BIOS SPI flash is a W25Q128FWSIQ with a capacity of 16MB.
Q: What EC/KBC and EC flash are used on this motherboard?
A: The EC/KBC is an Nuvoton NCT6686DL, and its dedicated EC flash is a W25X20CLSNIG with a capacity of 2Mb.
A: The motherboard supports DDR4-SO-DIMM memory across two banks, labeled BANK 0 and BANK 1.
Q: What is the graphics architecture of this motherboard?
A: The graphics are integrated into the AMD APU (FP5 Type2), which uses a lidless BGA package with a 0.64mm ball pitch, 1140 pins, dimensions of 25mm x 35mm, a 15W TDP, and a maximum frequency of 2400 MHz.
| Model | LS-K882P |
| Board Number | LS-E882P |
| Revision | 0.1 |
| Date | 2020-12-24 |
| Document Number | LS-E882P |
| PCB Number | ZZZPCB LS-K882P DA4002ZR010 |
| Board Number | LA-K901P |
| Revision | 0.1 |
| Date | Monday, January 25, 2021 |
| CPU Platform | AMD FP5 with DDR4 |
| EC / KBC | NCT6686DL |
| EC Flash / ROM | W25X20CLSNIG (2Mb) |
| BIOS / SPI Flash | W25Q128FWSIQ (16MB) |
| Audio Codec | Realtek ALC233 |
| LAN IC | Realtek RTL8111G/H |
| Card Reader IC | Realtek RTS5140 |
| USB Hub IC | GL852 |
| RAM Type | DDR4-SO-DIMM |
| RAM Architecture | BANK 0, 1 |
| Charging IC | TI 3110 |
| WiFi / WLAN IC | WLAN/BT |
| HDMI Level Shifter | RTD2136Ne |
| GPU Type | AMD APU (FP5 Type2) |
| Graphics Architecture | Lidless BGA 0.64mm ball pitch 1140 pins 25mm x 35mm 15W 2400 MHz Max |
LS-E882P
LA-K901P
AMD FP5 with DDR4
NCT6686DL
W25X20CLSNIG (2MB)
BIOS / EC Flash
ALC233
RTL8111G/H
RTS5140
GL852
DDR4-SO-DIMM
3110
WLAN / BT
RTD2136NE
AMD APU (FP5 Type2)
LS-E882P
LA-K901P
AMD FP5 with DDR4
NCT6686DL
W25X20CLSNIG (2MB)
BIOS / EC Flash
ALC233
RTL8111G/H
RTS5140
GL852
DDR4-SO-DIMM
3110
WLAN / BT
RTD2136NE
AMD APU (FP5 Type2)
