Lenovo AIO 520-24IKL LA-E881P Schematic
This Compal LA-E881P is an All-in-One motherboard designed for the Intel Kaby Lake-S platform with an LGA1151 socket, paired with an AMD GPU (M17) and a B250 PCH. The system memory architecture consists of two DDR4-SO-DIMM slots supporting dual-channel configuration. The main BIOS SPI flash is an 8MB W25Q64FVSSIQ, while the EC firmware is stored on a separate 128KB W25X20CLSNIG SPI ROM, managed by the NCT6685D EC. Audio is handled by a Realtek ALC274 codec, and networking is provided by a Realtek RTL8111G LAN IC. The board also features a Realtek RTS5170 card reader, an Anpec APA6003 audio amplifier, and an RTD2136R HDMI level shifter with an RTD2506S-CG HDMI converter. Optional TPM support includes Nuvoton NPCT650LBBYX, Infineon SLB9670VQ2.0, or ST ST33HTPH2E32AHA6.
[color=#2C82
| Model | LA-E881P |
| Board Number | LA-E881P |
| Revision | 0.3 |
| Date | 03/14, 2017 |
| CPU Platform | Intel Kaby Lake-S |
| CPU Socket | LGA1151 |
| PCH / Southbridge | B250 |
| GPU Type | AMD GPU |
| Graphics Architecture | AMD GPU (M17) |
| EC / KBC | NCT6685D |
| EC Flash / ROM | W25X20CLSNIG (128KB) |
| Audio Codec | Realtek ALC274 |
| BIOS / SPI Flash | W25Q64FVSSIQ (8MB) |
| BIOS Flash Exact Model | W25Q64FVSSIQ |
| BIOS Flash Capacity | 8MB |
| RAM Type | DDR4-SO-DIMM |
| RAM Architecture | Dual Channel (Channel A, Channel B) |
| RAM Quantity / Slots | 2 (BANK 0, 1 per channel) |
| Card Reader IC | Realtek RTS5170 |
| LAN IC | Realtek RTL8111G |
| WiFi / WLAN IC | WLAN/BT |
| HDMI Level Shifter | RTD2136R |
| Charging IC | Not explicitly present in source |
| Power IC(s) | Not explicitly present in source |
| Thermal Sensor | Not explicitly present in source |
| USB Hub IC | Not explicitly present in source |
| TPM | Nuvoton NPCT650LBBYX / Infineon SLB9670VQ2.0 / ST ST33HTPH2E32AHA6 (Option) |
| Audio Amplifier | Anpec APA6003 |
| HDMI Converter | RTD2506S-CG |
| EC/KBC Programmable | Not explicitly present in source |
| dGPU to UMA Conversion Support | Not explicitly present in source |
| Platform Alias | AIO M/B |
| Document Number | LA-E881P |
[color=#2C82
LA-E881P
Intel Kaby Lake-S
B250
AMD GPU
AMD GPU (M17)
NCT6685D
BIOS / EC Flash
ALC274
W25Q64FVSSIQ
BIOS / EC Flash
DDR4-SO-DIMM
RTS5170
RTL8111G
WLAN / BT
RTD2136R
LA-E881P
Intel Kaby Lake-S
B250
AMD GPU
AMD GPU (M17)
NCT6685D
BIOS / EC Flash
ALC274
W25Q64FVSSIQ
BIOS / EC Flash
DDR4-SO-DIMM
RTS5170
RTL8111G
WLAN / BT
RTD2136R
