lenovo e40 e50 gc6c ld-note amd uma danube uma r1a 0322 d final schematic 1
The Quanta LD-Note AMD UMA project, documented under number 1122334455667788AABBCCDD revision 1A dated March 22, 2010, is built around the AMD Danube S1G4 processor platform. Graphics are handled by the RS880M northbridge in UMA configuration, paired with the SB820M southbridge. System memory consists of two DDRIII-SODIMM slots supporting 1066/1333 MHz modules. The BIOS SPI flash is an MX25L1605A, while the embedded controller is an IT8502E with an associated ITE SPI ROM. Networking is provided by a Realtek RTL8111DL Gigabit LAN controller. Audio is managed by a Realtek ALC269Q codec, and a Realtek RTS5159 flash media card reader is present. The clock generator is an RTM880N-796, and the thermal sensor is a G990P11U.
Q: What BIOS flash IC is used on this motherboard?
A: The BIOS SPI flash is an MX25L1605A.
A: The embedded controller is an IT8502E, with an ITE SPI ROM for its firmware.
Q: What is the memory configuration of this motherboard?
A: The board supports two DDRIII-SODIMM slots running at 1066/1333 MHz.
Q: What is the graphics architecture of this platform?
A: The graphics architecture is UMA, utilizing the RS880M northbridge.
| Project Code | LD-Note AMD UMA |
| Date | Monday, March 22, 2010 |
| CPU Platform | AMD Danube S1G4 Processor |
| GPU Type | RS880M |
| Graphics Architecture | UMA |
| EC / KBC | IT8502E |
| EC Flash / ROM | ITE SPI ROM |
| BIOS / SPI Flash | MX25L1605A |
| RAM Type | DDRIII 1066/1333 MHz |
| RAM Architecture | DDRIII-SODIMM1, DDRIII-SODIMM2 |
| LAN IC | RTL8111DL |
| Audio Codec | ALC269Q |
| Card Reader IC | RTS5159 |
| Southbridge | SB820M |
| Clock Generator | RTM880N-796 |
| Thermal Sensor | G990P11U |
| Document Number | 1122334455667788AABBCCDD |
| Revision | 1A |
