If you have tested the peripherals such as RAM, hard drive, etc. and there is a problem with the motherboard, considering that it is not different from the BIOS, measure the voltage first and check that there is no voltage drop anywhere and that the board does not overheat.
Remove the sound and network ICs, etc., which have no effect on the image of the laptop.
Next, graphics and chipsets are suspect.
