Schematic Lenovo Flex 5 Chromebook 13ITL6 NM-D631 Schematic
BrandBitland
Project NameVeneno
Board NumberVolteer MLB
Revision1.0
DateMonday, March 29, 2021
CPU PlatformTGL-U
EC / KBCNPCX796FC0BX
BIOS / SPI FlashPCH BIOS Flash
BIOS Flash Capacity32mb
EC Flash / ROMInternal Flash 512KB
Charging ICISL9241
RAM TypeLPDDR4X
RAM Architecture4X32 LPDDR4X-4266
RAM Quantity / SlotsX4
Card Reader ICPCIe to SD Bridge IC
LAN ICRealtek 802.11ac
WiFi / WLAN ICHarrison Peak 22230 key E or Realtek 802.11ac
The Bitland Veneno Volteer MLB is a TGL-U platform motherboard designed for Chrome OS. The board utilizes an NPCX796FC0BX EC/KBC with 512KB of internal flash. System memory consists of 4X32 LPDDR4X-4266 across four slots. The PCH BIOS flash is a 32mb SPI ROM. Power management is handled by an ISL9241 buck-boost charger. Storage expansion is provided via an M.2 SSD NVMe/SATA/Optane 2280 key M slot. Wireless connectivity is supported by a Harrison Peak 22230 or Realtek 802.11ac module. A PCIe to SD Bridge IC manages the SD card interface.
A: The motherboard uses an NPCX796FC0BX EC/KBC with 512KB of internal flash.
A: The PCH BIOS flash is 32mb.
A: The board supports 4X32 LPDDR4X-4266 memory.
A: The charging IC is an ISL9241 buck-boost charger.
  • Lenovo Flex 5 Chromebook 13ITL6 NM-D631 Schematic.pdf
