Technical Support Lenovo G505 with LA-9912P Motherboard Power off issue
laup
I have a above laptop, the customer bought in the machine that was still powered from battery and quite warm. it didnt display at the time either.
Now i removed battery to cut power and cool down.
Now i have reseated and replaced ram, checked USB short circuit.
When i power the machine i get fan spin for 5 seconds then power off.
no backlight from lcd, so i believe it is not a bios issue?
I get ram error beeps when no ram is connected, it will stay on longer in this instance, but i would then need to d/c power to restart again
Unit powers off after fan spin, does not restart.
Cpu gets a little warm,I BGA bottom flowed CPU to see if that helps with rewelding, i still have same issue..
I think the CPU is dead?
Any ideas?
Any ideas?
did you reprogrammed the bios and ec ???
disconnect any components like dvd hdd wifi .... and test .
laup
i have not reprogrammed bios or EC as of yet.
i have ran with minumum config, no other external devices connected other than lcd
