lenovo ideapad 500-15acz compal la-c285p aawza
This Compal LA-C285P R1.0 motherboard, dated 2015-04-20, is built around the AMD Carrizo/Carrizo-L FP4 APU platform with integrated AMD FUSION APU graphics. The system memory architecture consists of single-channel DDR3L via two 204-pin SO-DIMM slots supporting up to 1600MHz. The embedded controller is a Nuvoton NPCE388NA0DX, and the audio subsystem is handled by a Realtek ALC3248 codec. The BIOS is stored on an 8MB SPI ROM. Networking is provided by a Realtek RTL8111H Gigabit LAN controller, with wireless connectivity via an NGFF (WLAN/BT) slot. A Parade PS8339B HDMI level shifter is used for display output. The card reader is managed by a Realtek RTS5170-GR controller, and thermal monitoring is handled by a TCMZ32H320TC sensor. The board also includes a Reserve USB Charger circuit.
A: The board number is LA-C285P, revision R1.0.
A: The EC/KBC is a Nuvoton NPCE388NA0DX.
A: The BIOS is stored on an 8MB SPI ROM.
A: The memory architecture is single-channel DDR3L, using two 204-pin SO-DIMM slots supporting up to 1600MHz.
Q: What LAN and audio controllers are used?
A: The LAN controller is a Realtek RTL8111H, and the audio codec is a Realtek ALC3248.
| Model | LA-C285P |
| Board Number | LA-C285P |
| Revision | R1.0 |
| Date | 2015-04-20 |
| CPU Platform | AMD Carrizo/Carrizo-L FP4 APU |
| EC / KBC | Nuvoton NPCE388NA0DX |
| Audio Codec | Realtek ALC3248 |
| BIOS / SPI Flash | SPI ROM (8MB) |
| Charging IC | Reserve USB Charger |
| RAM Type | DDR3L |
| RAM Architecture | Single Channel |
| RAM Quantity / Slots | 204pin DDR3L SO-DIMM X2 |
| Card Reader IC | Realtek RTS5170-GR |
| LAN IC | Realtek RTL8111H |
| WiFi / WLAN IC | NGFF (WLAN/BT) |
| HDMI Level Shifter | Parade PS8339B |
| GPU Type | AMD FUSION APU Carrizo/Carrizo-L FP4 APU |
| Graphics Architecture | AMD FUSION APU |
| dGPU Chip Number | AMD FUSION APU Carrizo/Carrizo-L FP4 APU |
| Thermal Sensor | TCMZ32H320TC |
LA-C285P
NPCE388NA0DX
ALC3248
RESERVE USB CHARGER
DDR3L
RTS5170-GR
RTL8111H
NGFF (WLAN/BT)
PS8339B
AMD FUSION APU
FUSION APU CARRIZO/CARRIZO-L FP4 APU
TCMZ32H320TC
LA-C285P
NPCE388NA0DX
ALC3248
RESERVE USB CHARGER
DDR3L
RTS5170-GR
RTL8111H
NGFF (WLAN/BT)
PS8339B
AMD FUSION APU
TCMZ32H320TC
