Lenovo Legion 5 15ACH6 NM-D601 Schematic
This LCFC Y560 motherboard schematic, revision 0.2 dated 2020-08-27, documents an AMD Cezanne-FP6_BGA1140 platform paired with an NVidia GN20-P0/P1 discrete GPU (N18P-G61-A). The system memory architecture consists of two DDR4-SO-DIMM slots supporting non-ECC DDR4 at 3200MT/s. The embedded controller is an ITE IT8227-LQFP128. The main BIOS is stored on a 32MB SPI ROM. Audio is handled by a Realtek ALC3306L codec. Networking includes a Realtek RTL8111H-CG LAN IC and an M.2 WLAN&BT card. The charging architecture is Type-C PD, managed by a CRTS5457V controller. The schematic also specifies a GL3523-OTY30 USB 3.2 Gen1 hub, a GL3213S SD card reader controller, a PS8461E HDMI level shifter, and an F75303M thermal sensor.
Q: What is the EC/KBC model used on this motherboard?
A: The embedded controller is an ITE IT8227-LQFP128.
Q: What is the BIOS flash configuration?
A: The main BIOS is stored on a 32MB SPI ROM.
Q: What is the discrete GPU configuration?
A: The motherboard uses an NVidia GN20-P0/P1 GPU, specifically the N18P-G61-A, with 4GB of GDDR6 memory.
A: The system supports DDR4 non-ECC memory at 3200MT/s via two DDR4-SO-DIMM slots.
Q: What is the charging architecture?
A: The motherboard uses a Type-C PD charging architecture with a CRTS5457V controller.
| Brand | LCFC |
| Model | Y560 |
| Motherboard Manufacturer | LC Future Center |
| Project Code | Y560 |
| Board Number | Y560 M/B |
| Revision | 0.2 |
| Date | 2020-08-27 |
| CPU Platform | AMD Cezanne-FP6_BGA1140 |
| GPU Type | NV N20 P0/P1 GPU |
| Graphics Architecture | NVidia GN20-P0/P1 |
| dGPU Chip Number | N18P-G61-A |
| EC / KBC | ITE IT8227-LQFP128 |
| Audio Codec | ALC3306L |
| BIOS / SPI Flash | 32MB SPI ROM |
| Charging IC | CRTS5457V |
| Charger Architecture | TypeC PD |
| RAM Type | DDR4 3200MT/s |
| RAM Architecture | DDR4 non-ECC |
| RAM Quantity / Slots | DDR4-SO-DIMM x2 |
| Thermal Sensor | F75303M |
| Card Reader IC | GL3213S |
| USB Hub IC | GL3523-OTY30 |
| LAN IC | RTL8111H-CG |
| WiFi / WLAN IC | M.2 Card (WLAN&BT) |
| HDMI Level Shifter | PS8461E |
Y560
Project Code
Y560 M/B
Board Number
AMD-Cezanne-FP6_BGA1140
NV N20 P0/P1 GPU
Graphics
NVidia GN20-P0/P1
Graphics
N18P-G61-A
Graphics
IT8227-LQFP128
ALC3306L
CRTS5457V
Charging / PD IC
DDR4 3200MT/S
F75303M
Thermal / Fan Control
GL3213S
Card Reader IC
GL3523-OTY30
USB Controller
RTL8111H_CG
LAN Controller
PS8461E
Signal Conditioning IC
Y560
Project Code
Y560 M/B
Board Number
NV N20 P0/P1 GPU
Graphics
NVidia GN20-P0/P1
Graphics
N18P-G61-A
Graphics
IT8227-LQFP128
ALC3306L
CRTS5457V
Charging / PD IC
DDR4 3200MT/S
F75303M
GL3213S
Card Reader IC
GL3523-OTY30
USB Controller
RTL8111H_CG
LAN Controller
PS8461E
