lenovo s100 bm5080 v1 2-bot schematic 1
The motherboard is identified as BH5080a_REV1.2 with a revision of REV0p4. The schematic includes reference designators for a CPU fan connector (CPUFAN1), an LCD connector (LCDCON1), a battery connector (BATCON1), an AC input connector (ACIN1), a PCI Express slot (MPCIE1), a SATA HDD connector (SATA_HDD1), an RJ45 Ethernet jack (JRJ45), and an internal speaker connector (INTSPK5). The board also features a crystal oscillator (Y5) and multiple programmable ICs including U515, U518, and U17, alongside various power management components such as PQ-series MOSFETs and PR-series resistors.
A: The board number is BH5080a_REV1.2 and the revision is REV0p4.
Q: What major connectors are present on this motherboard?
A: The schematic includes a CPU fan connector (CPUFAN1), LCD connector (LCDCON1), battery connector (BATCON1), AC input connector (ACIN1), PCI Express slot (MPCIE1), SATA HDD connector (SATA_HDD1), RJ45 Ethernet jack (JRJ45), and internal speaker connector (INTSPK5).
| Board Number | BH5080a_REV1.2 |
| Revision | REV0p4 |
