Lenovo ThinkBook 13s-IWL BM5884A Schematic
This Bitland V540 motherboard revision 1.32, dated February 20, 2019, is built around the Intel Whiskey Lake U (WHL-U_U42) platform in a BGA1528 package with a TDP of 15W. The system memory architecture consists of two SODIMM slots supporting DDR4. Graphics processing is handled by a discrete AMD R19-m18-70 GPU. The embedded controller is an ITE IT5576E, while the audio codec is an ALC3287. The primary BIOS SPI flash is a Winbond W25Q128JVZPIQ with 128MB capacity. Power management and charging are managed by a TI BQ24780 charger IC and an OZ8690 charger architecture. The board includes a TPM module based on the Z32H320TC, a USB hub controller TPS2546, a card reader controller RTS5457/PS8812, an APX8132 HDMI level shifter, and an RTERDPDDI LAN IC.
A: The BIOS SPI flash is a Winbond W25Q128JVZPIQ with 128MB capacity.
A: The embedded controller is an ITE IT5576E.
Q: What is the charging architecture of this motherboard?
A: The charging architecture uses a TI BQ24780 charger IC combined with an OZ8690 charger controller.
A: The motherboard supports DDR4 memory via two SODIMM slots.
| Brand | Bitland |
| Motherboard Manufacturer | Bitland Information Technology Co., Ltd. |
| Project Name | V540 |
| Revision | 1.32 |
| Date | Wednesday, February 20, 2019 |
| CPU Platform | Whiskey Lake U (WHL-U_U42) |
| CPU Socket | BGA1528 |
| GPU Type | AMD R19-m18-70 |
| EC / KBC | IT5576E / ITE |
| Audio Codec | ALC3287 |
| BIOS / SPI Flash | W25Q128JVZPIQ |
| BIOS Flash Manufacturer | Winbond |
| BIOS Flash Capacity | 128MB |
| Charging IC | BQ24780 / TI |
| Charger Architecture | OZ8690 |
| RAM Type | DDR4 |
| RAM Architecture | SODIMM |
| Card Reader IC | RTS5457 / PS8812 |
| USB Hub IC | TPS2546 |
| LAN IC | RTERDPDDI |
| WiFi / WLAN IC | BTM |
| HDMI Level Shifter | APX8132 |
| TPM | Z32H320TC |
