Lenovo ThinkCentre M90z IQ370SV Schematic
The Lenovo M920z/M828z motherboard, project code IQ370SVP, board number A3199 revision 1.0, is built on the Intel CFL-S 6+2 Processor 65W platform with an LGA1151 socket. The PCH is Q370 for M920z and B360 for M828z. Graphics are handled by an AMD R17M-M1-70 GPU with GB2b-64 architecture, supported by GDDR5 memory. The system uses DDR4 2400/2666 SO-DIMMs across two channels. The EC/KBC is an IT8738E, and the audio codec is an ALC233-VB2-CG. BIOS storage uses SPI Flash ROM with configurations of 16M+8M for M920z and 16+4M for M828z. Networking includes an Intel JACKSONVILLE LAN IC and an M.2 Socket E KEY CNVi WLAN slot. The scalar is an RTD2526-CG, and the HDMI level shifter is a PS8330B. The charging IC is an RTS5170-GR, and the USB hub IC is a TS3DV642.
Q: What BIOS flash configuration is used on the M920z/M828z?
A: The M920z uses a 16M+8M SPI Flash ROM configuration, while the M828z uses a 16+4M configuration.
Q: What EC/KBC chip is used on this motherboard?
A: The EC/KBC is an IT8738E.
Q: What is the GPU configuration on the M920z/M828z?
A: The motherboard uses an AMD R17M-M1-70 GPU with GB2b-64 architecture, supported by GDDR5 memory.
Q: What is the PCH difference between the M920z and M828z?
A: The M920z uses the Intel Q370 PCH, while the
| Brand | Lenovo |
| Model | M920z/M828z |
| Motherboard Manufacturer | Lenovo |
| Project Code | IQ370SVP |
| Board Number | A3199 |
| Revision | 1.0 |
| Date | Tuesday, March 06, 2018 |
| CPU Platform | CFL-S 6+2 Processor 65W Intel |
| CPU Socket | LGA1151 |
| PCH / Southbridge | Q370 for M920z, B360 for M828z |
| GPU Type | AMD R17M-M1-70 |
| Graphics Architecture | AMD GPU GB2b-64 |
| EC / KBC | IT8738E |
| Audio Codec | ALC233-VB2-CG |
| BIOS / SPI Flash | SPI Flash ROM (16M+8M for M920z, 16+4M for M828z) |
| Charging IC | RTS5170-GR |
| RAM Type | DDR4 2400/2666 |
| RAM Architecture | CHA SO-DIMM, CHB SO-DIMM |
| LAN IC | Intel JACKSONVILLE |
| WiFi / WLAN IC | M.2 Socket Slot E KEY TDP<= 6W CNVi |
| HDMI Level Shifter | PS8330B |
| Card Reader IC | HD |
| USB Hub IC | TS3DV642 |
| Scalar | RTD2526-CG |
| TPM | eSPI TPM |
| SIO | IT8738E |
| Document Number | A3299 |
IQ370SVP
Project Code
A3199
Board Number
B360 FOR M828Z
PCH / Southbridge
Q370 FOR M920Z
PCH / Southbridge
AMD R17M-M1-70
Graphics
AMD GPU GB2b-64
Graphics
IT8738E
ALC233-VB2-CG
RTS5170-GR
Charging / PD IC
DDR4 2400/2666
WiFi / WLAN
PS8330B
Signal Conditioning IC
TS3DV642
USB Controller
IQ370SVP
Project Code
A3199
Board Number
B360 FOR M828Z
PCH / Southbridge
Q370 FOR M920Z
PCH / Southbridge
AMD R17M-M1-70
Graphics
AMD GPU GB2b-64
Graphics
IT8738E
ALC233-VB2-CG
RTS5170-GR
Charging / PD IC
DDR4 2400/2666
WiFi / WLAN
PS8330B
TS3DV642
USB Controller
