lenovo thinkpad 10 compal la-a811p r10
This Compal ZIJI2 motherboard, documented under board number LA-A811P, is built around the Intel Bay Trail platform. The schematic revision is SOVP, dated June 3, 2014, and the PCB is identified as 11J LA-A811P REV0 M/B. The document is authored by Compal Electronics, Inc. and carries the document number ELLA LA-A811P. The revision history indicates progression from SDV through FVT, SIT, SVT, and SOVP stages, with specific ECR cuts for Richtek PW IC rework and component removal.
Q: What is the board number for this Compal ZIJI2 motherboard?
A: The board number is LA-A811P.
A: This motherboard uses the Intel Bay Trail platform.
Q: What is the PCB number for this motherboard?
A: The PCB number is 11J LA-A811P REV0 M/B.
| Model | ZIJI2 |
| Project Code | ZIJI2 |
| Board Number | LA-A811P |
| Revision | SOVP |
| Date | 2014-06-03 |
| CPU Platform | Intel Bay Trail |
| Document Number | ELLA LA-A811P |
| PCB Number | la-a811p-rev0-m-b/"]11J LA-A811P REV0 M/B[/URL] |
