Schematic Lenovo Thinkpad E14 Gen 4 AMD NM-E501 Schematic
BrandLCFC (LC Future Center)
ModelE14/E15 GEN4 N-1
Motherboard ManufacturerLC Future Center
Project CodeNM-E501
Board NumberNM-E501
RevisionRev0.3
Date2021-11-02
CPU PlatformAMD Barcelo FP6
EC / KBCITE8227E
Audio CodecRealtek ALC3287
BIOS / SPI FlashSPI Flash 256Mbits
Charging ICTI SN1702001
RAM TypeDDR4
RAM ArchitectureMemory down + DDR4 SO-DIMM
LAN ICRealtek RTS5457
WiFi / WLAN ICM.2 WLAN/BT
Card Reader ICRealtek RTS5457
USB Hub ICRealtek RTS5457
HDMI Level ShifterHDMI 1.4 Connector
GPU TypeAMD Barcelo FP6 (Integrated)
Graphics ArchitectureIntegrated
dGPU to UMA Conversion SupportNot applicable (Integrated GPU)
EC/KBC ProgrammableNot explicitly indicated
Charger ArchitectureAOU Charger
RAM Quantity / SlotsMemory down + 1x DDR4 SO-DIMM
Thermal SensorThermal Sensor
Power IC(s)TI SN1702001
This LCFC NM-E501 Rev0.3 motherboard is designed for the Lenovo ThinkPad E14/E15 GEN4 N-1 platform, built around the AMD Barcelo FP6 processor with integrated Radeon graphics. The board features dual-channel DDR4 memory architecture combining onboard memory-down with one DDR4 SO-DIMM slot. System firmware is stored on a 256Mbit SPI flash IC. Embedded controller functions are handled by an ITE8227E. Audio processing is managed by a Realtek ALC3287 codec. The charging subsystem uses a TI SN1702001 AOU charger IC. USB-C connectivity and card reader functions are supported by a Realtek RTS5457 controller. The board includes an HDMI 1.4 connector, M.2 WLAN/BT slot, and multiple USB 2.0 and USB 3.0 Gen 1 ports. The design date is November 2, 2021, with revision 0.3.
Q: What is the BIOS flash IC capacity on this motherboard?
A: The BIOS SPI flash is 256Mbits.
A: The embedded controller is an ITE8227E.
A: The board uses DDR4 memory with both memory-down and one DDR4 SO-DIMM slot.
A: The charging IC is a TI SN1702001 AOU charger.
A: The audio codec is a Realtek ALC3287.
BrandLCFC
ModelJE443 IO BOARD
Board NumberNS-E501 Rev0.3
RevisionRev0.3
Date2021-11-30
CPU Platform[URL="https://dr-bios.com/components/cpu-platform/amd-barcelo-fp6/"]AMD Barcelo FP6 Processor with DDR4[/URL]
LAN ICRealtek R8111GUS
This LCFC JE443 IO BOARD, board number NS-E501 Rev0.3, is designed around the AMD Barcelo FP6 Processor platform with DDR4 memory support. The schematic, dated 2021-11-30, is classified as LC Future Center Secret Data. The board integrates a Realtek R8111GUS Gigabit LAN controller for wired networking connectivity. The block diagram indicates support for PCIe x1, USB 2.0 ports, and a JYT JYAA139A fingerprint reader interface. This IO board serves as a peripheral and connectivity expansion module for the broader system architecture.
Q: What is the board number and revision of this IO board?
A: The board number is NS-E501 Rev0.3.
Q: What LAN IC is used on this board?
A: The LAN IC is a Realtek R8111GUS.
Q: What CPU platform does this board support?
A: This board supports the AMD Barcelo FP6 Processor with DDR4 memory.
  • Lenovo Thinkpad E14 Gen 4 AMD NM-E501 Schematic.pdf
  • Lenovo Thinkpad E14 Gen 4 AMD NS-E501 Schematic.pdf
