lenovo thinkpad sl410 gl40-0622 gc1a cg1b schematic 1
The Quanta G-Note Montevina motherboard, document number 3AB241 revision 3A dated June 1, 2009, is built around the Intel Montevina platform featuring a Penryn 478P (uPGA)/35W CPU and Cantiga graphics architecture. The system is powered by an ISL88731A system charger and uses ISL6266A, RT8204, TPS51116 REGR, and ISL6237 power ICs. Memory architecture supports two DDRIII SODIMM slots at 800/1066 MT/s. The embedded controller is an ITE IT8502E/JX, and the audio codec is an ALC269Q. Storage connectivity includes SATA0 and SATA1 at 300MB/s, with a JMB385 card reader controller and an RTL8111DL LAN IC. The SPI EEPROM handles BIOS storage, and the clock generator is an SLG8SP568/ICS9LPRS393 in a QFN68 package. A LIS244ALTR G-sensor is also integrated.
A: The embedded controller is an ITE IT8502E/JX.
Q: What is the charging architecture?
A: The system uses an ISL88731A system charger.
Q: What memory type and configuration does this board support?
A: It supports DDRIII 800/1066 MT/s across two SODIMM slots.
Q: What is the CPU platform and socket?
A: The platform is Montevina with a Penryn 478P (uPGA)/35W CPU.
Q: What audio codec is used?
A: The audio codec is an ALC269Q.
Technical data structured and organized by Dr-Bios.com
| Model | G-Note Montevina |
| Motherboard Manufacturer | Quanta Computer Inc. |
| Document Number | 3AB241 |
| Revision | 3A |
| Date | Monday, June 01, 2009 |
| CPU Platform | Montevina |
| CPU Model | Penryn 478P (uPGA)/35W |
| CPU Socket | 478P (uPGA) |
| PCH / Southbridge | ICH-9M |
| GPU Type | Cantiga |
| Graphics Architecture | Cantiga |
| EC / KBC | IT8502E/JX |
| EC/KBC Package | ITE |
| Audio Codec | ALC269Q |
| BIOS / SPI Flash | SPI EEPROM |
| Charging IC | ISL88731A |
| Charger Architecture | SYSTEM CHARGER |
| Power IC(s) | ISL6266A, RT8204, TPS51116 REGR, ISL6237 |
| RAM Type | DDRIII |
| RAM Architecture | DDRIII 800/1066 MT/s |
| Card Reader IC | JMB385 |
| LAN IC | RTL8111DL |
| WiFi / WLAN IC | WLAN/WiMAX/UWB |
| Thermal Sensor | CPU THERMAL SENSOR |
| Clock Generator | SLG8SP568/ICS9LPRS393 (QFN68) |
| G-Sensor | LIS244ALTR |
| PCB Stack Up | 6L |
Montevina
CPU Model
ICH-9M
Cantiga
Cantiga
IT8502E/JX
/ ALC269Q
ISL88731A
ISL6237
ISL6266A
RT8204
TPS51116 REGR
DDRIII
JMB385
RTL8111DL
WLAN/WiMAX/UWB
Clock Generator
Montevina
CPU Model
ICH-9M
Cantiga
Cantiga
IT8502E/JX
/ ALC269Q
ISL88731A
ISL6237
ISL6266A
RT8204
TPS51116 REGR
DDRIII
JMB385
RTL8111DL
WLAN/WiMAX/UWB
Clock Generator
