Schematic Lenovo Thinkpad T495 FA495 NM-C131 Schematic
BrandLC Future Center
ModelDrift AMD
Motherboard ManufacturerLC Future Center
Project CodeDrift AMD
Revision0.1
DateFriday, March 01, 2019
Document NumberCustom167
CPU PlatformAMD
EC / KBCIT8186E/FX
Audio CodecALC3287-CG
Charging ICBQ25700A
Card Reader ICMedia Card Controller
USB Hub ICUSB HUB
Thermal SensorTHERMAL SENSOR
The LC Future Center Drift AMD motherboard is an AMD platform design, revision 0.1, dated Friday, March 01, 2019, with document number Custom167. The system is managed by an IT8186E/FX embedded controller. Audio processing is handled by an ALC3287-CG codec. Battery charging is managed by a BQ25700A charger IC. The board features dual LAN controllers, including an 8111EPV for the dock and an 8111GUL for the system. A media card controller provides card reader functionality, and a USB hub IC is present for USB port expansion. Thermal monitoring is supported by a dedicated thermal sensor.
A: The embedded controller is an IT8186E/FX.
A: The audio codec is an ALC3287-CG.
A: The charging IC is a BQ25700A.
Q: What LAN controllers are used on this motherboard?
A: The board uses an 8111EPV for the dock LAN and an 8111GUL for the system LAN.
  • Lenovo Thinkpad T495 FA495 NM-C131 Schematic.pdf
