lenovo yoga 3 aizy0 la-b921p rev 1.0 (2014.10.17) 1
This Compal LA-B921P Rev 1.0 motherboard, model AIZY0, is built around the Intel Broadwell Y processor platform. The system memory configuration uses DDR3L across two channels, Ch0 and Ch1, populated with 8 memory chips. The BIOS SPI flash is an 8MB W25Q64FVSSIQ IC. Embedded controller functionality is handled by a Nuvoton NPCE288L. Audio is provided by a Realtek ALC233-VB2-CG codec. A Realtek RTS5170 IC manages the card reader interface, and thermal monitoring is performed by a Nuvoton NCT7718W sensor.
Q: What is the exact BIOS flash IC model used on this motherboard?
A: The BIOS flash IC is a W25Q64FVSSIQ, which is an 8MB SPI ROM.
A: The embedded controller is a Nuvoton NPCE288L.
Q: What is the memory configuration for this board?
A: The board uses DDR3L memory across two channels (Ch0, Ch1) with 8 memory chips total.
| Model | AIZY0 |
| Board Number | LA-B921P |
| Date | 2014-09-30 |
| CPU Platform | Intel Broadwell Y |
| EC / KBC | Nuvoton NPCE288L |
| Audio Codec | Realtek ALC233-VB2-CG |
| BIOS / SPI Flash | SPI ROM (8MB) |
| BIOS Flash Exact Model | W25Q64FVSSIQ |
| BIOS Flash Capacity | 8MB |
| Card Reader IC | Realtek RTS5170 |
| Thermal Sensor | Nuvoton NCT7718W |
| RAM Type | DDR3L |
| RAM Architecture | Ch0, Ch1 |
| RAM Quantity / Slots | 8pcs |
