lg r510 quanta_ql8_rev3a schematic
lg r510=1=quanta_ql8_rev3a.pdf
The Quanta QL8NB5 project is a laptop motherboard platform dated April 2, 2008, built around the Intel Penryn 478P (uPGA) CPU with a Cantiga Northbridge and ICH9-M Southbridge. Graphics are handled by either an NVIDIA NB9M-64bit or NB9P-GE2 128bit GPU. The system uses an ENE KBC controller, which is programmable, and features an ISL6251AHAZ-T charging IC along with multiple power ICs including ISL6237IRZ-T, ISL6266A, TPS51116REGR, RT8204, and Oz8118. Memory configuration consists of two DDRII SODIMM slots supporting DDRII 667/800 MHz. Audio is provided by an ALC268 codec with a TPA6017A2 amplifier, while networking is handled by an RTL8102E/8111C LAN IC. The board also includes an RTS5158E card reader, a PS8101 clock generator, and an ALPRS355B thermal sensor.
A: The motherboard uses an ENE KBC controller, which is programmable.
A: The system charger is an ISL6251AHAZ-T.
A: The board supports two DDRII SODIMM slots running at DDRII 667/800 MHz.
Q: What audio codec and amplifier are used?
A: The audio codec is an ALC268, paired with a TPA6017A2 audio amplifier.
A: The LAN IC is an RTL8102E/8111C.
| Brand | Quanta |
| Project Code | QL8NB5 |
| Date | Wednesday, April 02, 2008 |
| CPU Platform | Penryn 478P (uPGA)/35W |
| Northbridge | Cantiga |
| Southbridge | ICH9-M |
| GPU Type | NVIDIA NB9M-64bit or NB9P-GE2 128bit |
| EC / KBC | ENE KBC |
| Audio Codec | ALC268 |
| LAN IC | RTL8102E/8111C |
| Charging IC | ISL6251AHAZ-T |
| Power IC(s) | ISL6237IRZ-T, ISL6266A, TPS51116REGR, RT8204, Oz8118 |
| RAM Type | DDR II |
| RAM Architecture | DDRII 667/800 MHz |
| Audio Amplifier | TPA6017A2 |
| Card Reader IC | RTS5158E |
| Clock Generator | PS8101 |
| Thermal Sensor | ALPRS355B MLF64PIN |
| EC/KBC Programmable | Yes |
QL8NB5
Penryn 478P (uPGA) / 35W
ICH9-M
KBC
ALC268
RTL8102E/8111C
ISL6251AHAZ-T
ISL6237IRZ-T
ISL6266A
OZ8118
RT8204
TPS51116REGR
DDR(II)
RTS5158E
PS8101
Clock Generator
ALPRS355B MLF64PIN
QL8NB5
ICH9-M
KBC
ALC268
RTL8102E/8111C
ISL6251AHAZ-T
ISL6237IRZ-T
ISL6266A
OZ8118
RT8204
TPS51116REGR
DDR(II)
RTS5158E
PS8101
Clock Generator
ALPRS355B MLF64PIN
