MSI MS-16P1 MS-16P11 - MS-17C1 MS-17C11 Schematic
The MSI MS-16P1 motherboard is built on the Intel Kabylake platform with an HM175 PCH-H southbridge. It features an nVIDIA N17E-G2 (GTX 1070) discrete GPU in a GB4-256 2152-ball BGA package. The system memory architecture consists of dual-channel DDR4 via two SODIMM slots. The embedded controller is an ENE9028 with a dedicated EC ROM. Audio processing is handled by an ALC1220-CG codec paired with an ALC1305 amplifier. Power management includes a BQ24780RUYR charging IC and a comprehensive array of voltage regulators including ISL95855, APW8819QAI, APW8819QA, MP2249DN, TPS51225CRUK, NB671LGQ, TPS51216RUKR, UP9509PQAG, APL5912KAC-TR, ISL95808HRZ-TS2378, NB681GD-Z, UP16666QQKE, and BMP2143DJ. Connectivity is supported by an ASM1142 USB hub controller, an E2500 LAN IC, and an RTS5250 card reader.
Q: What EC/KBC is used on the MS-16P1 motherboard?
A: The embedded controller is an ENE9028 with a dedicated EC ROM.
Q: What is the discrete GPU configuration on this motherboard?
A: The motherboard uses an nVIDIA N17E-G2 (GTX 1070) GPU in a GB4-256 2152-ball BGA package.
Q: What charging IC is used on the MS-16P1?
A: The charging IC is a BQ24780RUYR.
A: The memory architecture is dual-channel DDR4 using two SODIMM slots.
| Brand | MSI (Micro-Star International) |
| Model | MS-16P1 |
| Motherboard Manufacturer | MICRO-STAR INT'L CO., LTD. |
| Board Number | MS-16P1 |
| Revision | 1.2 |
| Date | Wednesday, May 03, 2017 |
| CPU Platform | Intel Kabylake |
| PCH / Southbridge | Intel KBL PCH-H (HM175) |
| GPU Type | nVIDIA N17E-G2 (GTX 1070) |
| Graphics Architecture | GB4-256_37.5*37.5mm 2152-Ball BGA |
| EC / KBC | ENE9028 |
| EC Flash / ROM | EC ROM |
| Audio Codec | ALC1220-CG |
| Audio Amplifier | ALC1305 |
| Charging IC | BQ24780RUYR |
| Power IC(s) | ISL95855, APW8819QAI, APW8819QA, MP2249DN, TPS51225CRUK, NB671LGQ, TPS51216RUKR, UP9509PQAG, APL5912KAC-TR, ISL95808HRZ-TS2378, NB681GD-Z, UP16666QQKE, BMP2143DJ |
| RAM Type | DDR4 |
| RAM Quantity / Slots | 2 (SODIMM A, SODIMM B) |
| Card Reader IC | RTS5250 |
| USB Hub IC | ASM1142 |
| LAN IC | E2500 |
| WiFi / WLAN IC | WLAN/BT |
| HDMI Level Shifter | SV3H632DS AMP ESSES9023 |
MS-16P1
Board Number
Intel Kabylake
KBL PCH-H (HM175)
PCH / Southbridge
Graphics
Graphics
ENE9028
EC ROM
BIOS / EC Flash
ALC1220-CG
BQ24780RUYR
Charging / PD IC
APL5912KAC-TR
Power IC
APW8819QA
Power IC
APW8819QAI
Power IC
BMP2143DJ
Power IC
ISL95808HRZ-TS2378
Power IC
ISL95855
Power IC
MP2249DN
Power IC
NB671LGQ
Power IC
NB681GD-Z
Power IC
TPS51216RUKR
Power IC
TPS51225CRUK
Power IC
UP16666QQKE
Power IC
UP9509PQAG
Power IC
DDR4
RTS5250
Card Reader IC
ASM1142
USB Controller
E2500
LAN Controller
WLAN / BT
WiFi / WLAN
Signal Conditioning IC
MS-16P1
Board Number
Intel Kabylake
KBL PCH-H (HM175)
PCH / Southbridge
Graphics
Graphics
ENE9028
EC ROM
BIOS / EC Flash
ALC1220-CG
BQ24780RUYR
Charging / PD IC
APL5912KAC-TR
Power IC
APW8819QA
Power IC
APW8819QAI
Power IC
BMP2143DJ
Power IC
ISL95808HRZ-TS2378
Power IC
ISL95855
Power IC
MP2249DN
Power IC
NB671LGQ
Power IC
NB681GD-Z
Power IC
TPS51216RUKR
Power IC
TPS51225CRUK
Power IC
UP16666QQKE
Power IC
UP9509PQAG
Power IC
DDR4
RTS5250
Card Reader IC
ASM1142
USB Controller
E2500
LAN Controller
WLAN / BT
WiFi / WLAN
