msi ms-7211 ver 0a
The MSI MS-7211 revision 0A motherboard, dated July 28, 2005, is built around the Intel Prescott LGA775 CPU platform with a VIA P4M800_CE northbridge and VT8237_PLUS southbridge chipset. It features two DDR memory slots, two PCI 2.3 slots, and an AGP slot. The system uses an LPC FLASH ROM for BIOS storage. The embedded controller is a Winbond W83627EHF Super I/O, which also handles fan control. Audio is provided by a Realtek ALC655 AC'97 codec, and networking is supported by either a Realtek RTL8100C (10/100) or RTL8110SB (Gigabit) LAN controller. Power delivery is managed by an Intersil 6566 3-phase VRM controller. The clock generation is handled by a Realtek RTM862-520 or ICS ICS950917AF clock generator. Storage connectivity includes IDE and SATA ports.
Q: What BIOS flash type is used on this MSI MS-7211 motherboard?
A: The motherboard uses an LPC FLASH ROM for BIOS storage.
Q: What is the embedded controller / Super I/O chip on this board?
A: The board uses a Winbond W83627EHF Super I/O, which also serves as the EC/KBC.
Q: What LAN controller options are available on this motherboard?
A: The board supports either a Realtek RTL8100C (10/100) or Realtek RTL8110SB (Gigabit) LAN controller.
Q: What is the VRM configuration on this motherboard?
A: The VRM is an Intersil 6566 3-phase PWM controller.
| Brand | MSI (MICRO-STAR INT'L CO.,LTD.) |
| Model | MS-7211 |
| Board Number | MS-7211 |
| Revision | 0A |
| Date | Thursday, July 28, 2005 |
| CPU Platform | Intel Prescott LGA775 |
| Chipset | VIA P4M800_CE + VT8237_PLUS |
| EC / KBC | Winbond W83627EHF |
| Audio Codec | Realtek ALC655 |
| BIOS / SPI Flash | LPC FLASH ROM |
| LAN IC | Realtek RTL8100C / RTL8110SB |
| RAM Type | DDR |
| Super I/O | Winbond W83627EHF |
| Clock Generator | Realtek RTM862-520 / ICS ICS950917AF |
| VRM Controller | Intersil 6566 |
| VRM Phase | 3 |
| Expansion Slots | PCI 2.3 SLOT * 2, AGP SLOT |
| Storage Interfaces | IDE Connectors, SATA |
