Schematic MSI MS-9587 Rev 2.1 Schematic
BrandMICRO-STAR
Document NumberMS-9587
Revision2.1
DateWednesday, August 22, 2007
PCB NumberPCB_MS-9587-2.1
Thermal SensorF75383S
This MICRO-STAR MS-9587 revision 2.1 motherboard schematic, dated August 22, 2007, is documented with PCB identifier PCB_MS-9587-2.1. The design incorporates a F75383S system temperature monitor IC for thermal management. The board layout includes multiple fan headers, SAS and SATA connectors, a COM port, USB ports, and front panel button/LED connectors. A dedicated JDBG1 debug connector is present on the board. The schematic also details a SAF-TE enclosure management interface with a T125C-3.3V-SOIC8 device.
Q: What is the document number and revision of this motherboard?
A: The document number is MS-9587, revision 2.1.
Q: What temperature monitoring IC is used on this board?
A: The board uses a F75383S temperature monitor IC.
Q: What is the PCB identifier for this motherboard?
A: The PCB identifier is PCB_MS-9587-2.1.
  • MSI MS-9587 Rev 2.1 Schematic.pdf
