MSI MS-95B3 ULTRA 320 SCSI CARD Rev 10A Schematic
This document covers the MSI MS-95B3 REV 1.0 ULTRA 320 SCSI CARD, a PCI slot add-in card designed around the AIC7902 SCSI controller. The board is documented under drawing number 95B3-10A10A, dated Friday, June 11, 2004. The card features a PCI interface compliant with PCI VER: 2.2 and includes a PCI-X 100 connector (J1X_PCI-X). The schematic details the PCI slot interface, golden finger connections, and associated passive components including bulk capacitance (CT7, CT6) and decoupling capacitors (C3K, C2K). The board is configured with jumper options (J3, J2) for signal routing.
Q: What is the board number and revision of this SCSI card?
A: The board is the MSI MS-95B3 REV 1.0.
Q: What SCSI controller is used on this card?
A: The card uses the AIC7902 SCSI controller.
Q: What is the bus interface of this card?
A: The card uses a PCI Slot interface compliant with PCI VER: 2.2, with support for PCI-X 100.
| Brand | MSI |
| Model | ULTRA 320 SCSI CARD |
| Board Number | MS-95B3 REV 1.0 |
| Document Number | 95B3-10A10A |
| Date | Friday, June 11, 2004 |
| SCSI Controller | AIC7902 |
| Bus Interface | PCI Slot (PCI VER: 2.2 COMPLY) |
