Schematic MSI MS-9632 Rev 10 1.3 10b 10a 0a Schematic
Salim Badakhshan
BrandMSI (Micro-Star International)
ModelMS-9631
Motherboard ManufacturerMICRO-STAR INT'L CO., LTD.
Board NumberMS-9631
Revision0A
DateFriday, December 09, 2005
CPU PlatformIntel Yonah/Merom Processor
PCH / SouthbridgeIntel ICH7M-DH
GPU Type[URL="https://dr-bios.com/components/gpu/945gt/"]Intel 945GT[/URL] - GMCH (North Bridge)
EC / KBCW83627EHF
Audio CodecAzalia ALC880
BIOS / SPI FlashFWH EEPROM
Charging ICISL6262
RAM TypeDDR2
RAM Quantity / Slots2
LAN ICIntel 82573E
Card Reader ICVIA VT6307
USB Hub ICSIL 3132
WiFi / WLAN ICIntel 82573E
HDMI Level ShifterCH7307
TPMInfineon SLD9635
Clock GeneratorICS954129
Super I/OW83627EHF
Power ControllerISL6262
SATA ControllerSIL 3132
IEEE 1394 ControllerVIA VT6307
The MSI MS-9631 motherboard, revision 0A, is built around the Intel 945GT GMCH north bridge and ICH7M-DH south bridge, supporting Intel Yonah or Merom processors. System memory consists of two DDR2 DIMM slots with a maximum capacity of 4GB. The board utilizes an FWH EEPROM for BIOS storage and features the W83627EHF Super I/O and EC/KBC controller. Audio is handled by the Azalia ALC880 codec, while networking is provided by dual Intel 82573E LAN controllers. The VIA VT6307 controller manages IEEE 1394 connectivity, and the SIL 3132 controller provides SATA II support. A CH7307 level shifter enables DVI output, and the ISL6262 IMVP-6 controller manages CPU core voltage. The ICS954129 clock generator provides system timing, and an Infineon SLD9635 TPM module is included for security.
Q: What type of BIOS flash is used on this motherboard?
A: The MS-9631 uses an FWH (Firmware Hub) EEPROM for BIOS storage, connected via the LPC bus.
A: The W83627EHF Super I/O controller serves as the EC/KBC on this board.
Q: What is the charging/power controller for the CPU?
A: The ISL6262 IMVP-6 controller manages the CPU core voltage regulation.
A: The Azalia ALC880 codec provides audio functionality.
ModelMS-9632
Motherboard ManufacturerMICRO-STAR INt'L CO., LTD.
Board Numberms-9632-1-3/"]MS-9632 1.3[/URL]
Revision1.3
DateThursday, April 19, 2007
CPU SocketIntel Yonah Processor/Intel Merom Processor
PCH / SouthbridgeIntel ICH7R (South Bridge)
GPU TypeIntel 945 GT - GMCH (North Bridge)
Graphics ArchitectureIntel 945GT
EC / KBCWinbond W83627EHF
Audio CodecAzalia ALC880 / ALC883 / ALC888
BIOS / SPI FlashFWH EEPROM / SPI
Charging ICISL 6262
Power IC(s)isl6262/"]IMVP-6 Controller: ISL6262[/URL]
RAM TypeDDR2
RAM ArchitectureDDR2 System Memory 1 & 2
RAM Quantity / SlotsDDR 2 * 2 (Max 4GB)
LAN ICIntel 82573E
Card Reader IC[URL="https://dr-bios.com/components/card-reader-ic/vt6307/"]VIA VT6307 IEEE1394 Controller[/URL]
USB Hub ICVIA-6307 IEEE1394 Controller
Thermal SensorInfineon SLD9635 TPM
SATA Controller[URL="https://dr-bios.com/components/storage-controller/sil3132/"]SIL 3132 SATA2 Controller[/URL]
The MSI MS-9632 revision 1.3 motherboard, dated April 19, 2007, is built around the Intel Yonah/Merom processor platform with an Intel 945 GT GMCH north bridge and Intel ICH7R south bridge. System memory consists of two DDR2 slots supporting up to 4GB. The board utilizes a Winbond W83627EHF Super I/O for LPC and EC/KBC functions. Audio is provided by an Azalia ALC880/883/888 codec. Networking is handled by an Intel 82573E LAN controller. The BIOS is stored on a FWH EEPROM with SPI interface support. Power management is controlled by an ISL6262 IMVP-6 controller. The board includes a VIA VT6307 IEEE1394 controller, a CH7307 HDMI level shifter, and a SIL 3132 SATA2 controller. Clock generation is managed by an ICS954129 clock generator. A TPM module from Infineon (SLD9635) is also present.
Q: What BIOS flash technology is used on this motherboard?
A: The MS-9632 uses a FWH EEPROM with SPI (Serial Peripheral Interface) support for the BIOS flash device.
A: The board uses a Winbond W83627EHF Super I/O controller for LPC and EC/KBC functions.
Q: What is the power management controller on this board?
A: The board uses an ISL6262 IMVP-6 controller for CPU V-core PWM regulation.
A: The board supports Azalia ALC880, ALC883, or ALC888 audio codecs.
ModelMS-9631
Board NumberMS-9631
Revision0A
DateWednesday, February 22, 2006
EC / KBCW83627EHF
Charging ICISL6262
RAM TypeDDR 2
RAM Quantity / Slots2 (Max 4GB)
LAN ICIntel 82573E
TPMInfineon SLD9635
DVI TransmitterCH7307
Super I/OW83627EHF
The MSI MS-9631 (Revision 0A) motherboard is built around the Intel Yonah/Merom processor platform with the Intel 945GT GMCH (North Bridge) and Intel ICH7M-DH (South Bridge). System memory is supported via two DDR2 DIMM slots with a maximum capacity of 4GB. The board utilizes an FWH EEPROM for BIOS storage and features the W83627EHF Super I/O and EC/KBC controller. Audio is handled by the Azalia ALC880 codec, while networking is provided by the Intel 82573E LAN controller. The VIA VT6307 IEEE 1394 controller and SIL 3132 SATA II controller expand connectivity options. Power management is governed by the ISL6262 IMVP-6 controller, and clock generation is managed by the ICS954129. The board also includes an Infineon SLD9635 TPM module and a CH7307 DVI transmitter.
Q: What BIOS type is used on the MSI MS-9631?
A: The board uses an FWH EEPROM for BIOS storage.
A: The W83627EHF Super I/O serves as the EC/KBC controller.
Q: What is the CPU platform and chipset configuration?
A: The board supports Intel Yonah/Merom processors with the Intel 945GT GMCH (North Bridge) and Intel ICH7M-DH (South Bridge).
Q: What memory configuration does the MS-9631 support?
A: It supports DDR2 memory via two DIMM slots with a maximum capacity of 4GB.
ModelMS-9631
Motherboard ManufacturerMICRO-STAR INt'L CO. , LTD.
Board NumberMS-9631
Revision0A
DateThursday, April 20, 2006
CPU SocketYonah 478pin socket (keyed)
EC / KBCW83627EHF
Charging ICISL6262
Power IC(s)ISL6262
RAM TypeDDR2
RAM Architecture2 DDR II Modules
LAN ICIntel 82573E
Card Reader ICVIA-6307 IEEE1394 Controller
The MSI MS-9631 motherboard, revision 0A, is built around the Intel Yonah/Merom processor platform using a Yonah 478-pin socket. The system chipset consists of the Intel 945 GT GMCH (North Bridge) paired with the Intel ICH7M-DH (South Bridge). Memory architecture supports up to 4GB of DDR2 across two modules. The onboard EC/KBC is a Winbond W83627EHF LPC Super I/O controller. Audio is handled by an Azalia ALC880 codec. The BIOS is stored on a Firmware Hub (FWH) EEPROM. Power management uses an ISL6262 IMVP-6 controller for V-core PWM. Networking is provided by an Intel 82573E LAN controller. The board includes a VIA-6307 IEEE1394 controller for FireWire connectivity.
Q: What is the board number and revision of this motherboard?
A: The board number is MS-9631, revision 0A.
A: The EC/KBC is a Winbond W83627EHF LPC Super I/O controller.
Q: What type of BIOS storage is used on this motherboard?
A: The BIOS is stored on a Firmware Hub (FWH) EEPROM.
Q: What is the CPU platform and socket type?
A: The CPU platform is Intel Yonah/Merom, using a Yonah 478-pin socket.
Q: What charging and power IC is used for V-core regulation?
A: The V-core PWM controller is an ISL6262 IMVP-6 controller.
ModelMS-9632
Board Numberms-9632-1-0-ms-9632-1-0a-ms-9632-1b/"]MS-9632 1.0 / MS-9632 1.0A / MS-9632 1B[/URL]
Revision1B
DateTuesday, March 20, 2007
Document Number11AAMS-96322007.03.08
CPU SocketIntel Yonah CPU
PCH / Southbridge
NorthbridgeIntel 945 GT - GMCH
SouthbridgeIntel ICH7R / ICH7M-DH / ICH7M
GPU TypeIntegrated ([URL="https://dr-bios.com/components/gpu/945gt/"]Intel 945GT[/URL])
EC / KBCN/A (LPC I/O used instead)
Audio Codecalc888/"]Azalia ALC888[/URL]
BIOS Flash InterfaceFWH / SPI
Charging ICN/A (Desktop board)
Power IC(s)ISL6262 (V-core PWM, IMVP-6 Controller)
RAM TypeDDR2
RAM Architecture2 DIMM Modules (Dual Channel)
LAN ICIntel 82573E
WiFi / WLAN ICMini PCI type III *1
Card Reader ICVIA VT6307 (IEEE1394 Controller)
USB Hub ICN/A (Southbridge integrated)
HDMI Level ShifterCH7307 (DVI/TVOUT)
Super I/OWinbond W83627EHF
SATA ControllerSIL 3132 (SATA2)
TPMInfineon SLD9635
System Power PWMMS-7 & MS-6 Plus
Expansion SlotsPCI 2.3 Slot *1, PCI Express X16 Slot1, Mini PCI type III *1
The MSI MS-9632 motherboard, documented under revision 1B with document number 11AAMS-96322007.03.08, is built around the Intel 945 GT - GMCH northbridge paired with an ICH7R/ICH7M-DH/ICH7M southbridge, supporting Intel Yonah or Merom processors. System memory consists of two DDR2 DIMM slots supporting up to 4GB in dual-channel configuration. The board utilizes an FWH EEPROM or SPI serial peripheral interface for BIOS flash storage. Power management is handled by the ISL6262 IMVP-6 V-core PWM controller alongside MS-7 and MS-6 Plus system power PWMs. Integrated graphics from the Intel 945GT chipset is supplemented by a CH7307 DVI/TVOUT controller. Audio is provided by the Azalia ALC888 codec, while networking is handled by dual Intel 82573E LAN controllers. The Winbond W83627EHF Super I/O manages LPC bus connectivity, and the ICS954129 clock generator
ModelMS-9632
Board NumberMS-9632
Revision1A
DateThursday, May 11, 2006
EC / KBCW83627EHF
Charging ICISL6262
RAM TypeDDR2
LAN ICIntel 82573E
The MSI MS-9632 motherboard, revision 1A, dated May 11, 2006, is built around the Intel Yonah/Merom processor platform with an Intel 945GT GMCH north bridge and Intel ICH7M-DH south bridge. System memory consists of two DDR2 slots supporting up to 4GB. The board utilizes an FWH EEPROM for BIOS storage and features a Winbond W83627EHF LPC Super I/O controller. Audio is handled by an Azalia ALC880 codec, while networking is provided by dual Intel 82573E LAN controllers. A VIA VT6307 IEEE 1394 controller is present for FireWire connectivity, and a CH7307 chip enables DVI output. The voltage regulation is managed by an ISL6262 IMVP-6 controller. Expansion includes one PCI 2.3 slot, one PCI Express x16 slot, and one Mini-PCI Type III slot.
A: The board uses a Winbond W83627EHF LPC Super I/O controller.
A: The board supports Intel Yonah/Merom processors with an Intel 945GT GMCH north bridge and Intel ICH7M-DH south bridge.
A: The board uses an Azalia ALC880 audio codec.
  • MSI MS-9632 Rev 0a-1212-1100ori Schematic.pdf
  • MSI MS-9632 Rev 1.3 Schematic.pdf
  • MSI MS-9632 Rev 10 Schematic.pdf
  • MSI MS-9632 Rev 10-0420-1116-Schematic Schematic.pdf
  • MSI MS-9632 Rev 10B-0308 Schematic.pdf
  • MSI MS-9632-02S Rev 10a-0511-1109(std) Schematic.pdf
