MSI MS-AD211 Schematic
This MS-AD211N1 Ver 10 motherboard by MICRO-STAR INT'L CO., LTD. is built around an IMVP7 CPU platform with DDR3 SODIMM memory architecture supporting two slots. The system power management is handled by an NCP6132A 3+2 phase controller with NCP5914 drivers, while the SIO is a SCH5627 which integrates thermal monitoring. Audio is provided by an ALC262 codec, and networking by a BCM57781 LAN controller. The board includes USB 3.0 ports, HDMI, CRT, Thunderbolt, WLAN, and a card reader. Voltage rails include +VCC_CORE, +VCC_GFXCORE, VCCSA, and DDR VTT. The schematic indicates support for Thunderbolt and ITV/Audio switching.
A: The board number is MS-AD211, revision 10 (MS-AD211N1 Ver 10).
A: The EC/KBC is the SCH5627 SIO.
A: The power architecture uses an IMVP7 NCP6132A 3+2 phase controller with NCP5914 drivers.
A: It supports DDR3 memory in two SODIMM slots.
Reuse permitted only with source attribution.
| Brand | MICRO-STAR INT'L CO., LTD. |
| Board Number | MS-AD211 |
| Revision | 10 |
| Date | Friday, February 10, 2012 |
| CPU Platform | IMVP7 |
| Graphics Architecture | GMCH Graphics core rail (VCC_GFXCORE) |
| EC / KBC | SCH5627 |
| Audio Codec | ALC262 |
| LAN IC | BCM57781 |
| Charging IC | NCP6132A |
| Power IC(s) | NCP6132A (3+2 Phase), NCP5914 (Driver), IMPV7- NCP6132A |
| RAM Type | DDR3 |
| RAM Architecture | DDR3 SODIMM |
| RAM Quantity / Slots | 2 (DDR3 SODIMM 0, DDR3 SODIMM 1) |
| Thermal Sensor | SCH5627 (SIO) |
| Card Reader IC | Card Reader (referenced on page 23) |
| USB Hub IC | USB 3.0 (1,2), USB 3.0 (3,4) |
| WiFi / WLAN IC | WLAN (referenced on page 28) |
| HDMI Level Shifter | HDMI (referenced on page 20) |
| dGPU to UMA Conversion Support | Not explicitly indicated |
MS-AD211
Board Number
IMVP7
Graphics
SCH5627
ALC262
BCM57781
LAN Controller
NCP6132A
Charging / PD IC
IMPV7- NCP6132A
Power IC
NCP5914 (DRIVER)
Power IC
NCP6132A (3+2 PHASE)
Power IC
DDR3
SCH5627 (SIO)
Thermal / Fan Control
CARD READER (REFERENCED ON PAGE 23)
Card Reader IC
2)
USB Controller
4)
USB Controller
USB 3.0 (1
USB Controller
USB 3.0 (3
USB Controller
WiFi / WLAN
HDMI (REFERENCED ON PAGE 20)
Signal Conditioning IC
MS-AD211
Board Number
IMVP7
Graphics
SCH5627
ALC262
BCM57781
LAN Controller
NCP6132A
Charging / PD IC
IMPV7- NCP6132A
Power IC
NCP5914 (DRIVER)
Power IC
Power IC
DDR3
SCH5627 (SIO)
Card Reader IC
2)
USB Controller
4)
USB Controller
USB 3.0 (1
USB Controller
USB 3.0 (3
USB Controller
WiFi / WLAN
