Technical Support Not detect keyboard HP MINI 210-1014TU
Dulur
I have a problem on the HP MINI 210-1014TU not detecting the keyboard even though I replace a new keyboard, on the CN20 socket the required voltage appears all (pins 25,26,27 and pin 30 all appear 3volt).
Please help with the solution, which block should I check?
is it possible that the IO is broken?
when you want help you must share all information of laptop . what is motherboard model number bro ?
