How to fix hard drive M.2 can detected in BIOS and CMOS then we installed windows on it unknow M.2 SSD?
What is solution fo fix this problem.
ASUS ViVoBook 14 No Detect M.2 SSD
Is not detected during windows instalation ? If yes you need during instalation install Rapid Store Technology drivers then will see ssd. I have this troubles 100 times on several pc and always is help
Unpack Archive
copy it to usb with system
Boot from USB with system
select install drivers when is prompt thats ssd not detected
select folder with drivers
select first available
should work
Good luck
