other-brands a14hv v43h
The Shuttle Inc A14HV02 motherboard is built on the Sandy Bridge processor platform with a Cougar Point PCH, documented with a release date of Tuesday, September 21, 2010. The system utilizes an IT8518 embedded controller in a 128-pin LQFP package for EC/KBC functions. BIOS storage is provided by a Flash Rom 2 IC in an 8-pin M-SOP package connected via SPI. Audio processing is handled by a 92HD88B4 codec. The charging architecture employs an OZ8602 battery charger IC, while power regulation is managed by a comprehensive set of ICs including ISL62881, OZ8116, OZ815, OZ8291, OZ8033, FP6137, APL5315, APL1084, AM4826, and AM4828. Memory configuration supports dual-channel DDR3 across two SO-DIMM slots. Networking is provided by a JMC251 LAN controller, and HDMI connectivity is enabled via a CH7318B level shifter. The same JMC251 IC also serves as the card reader controller.
Q: What EC/KBC chip is used on this motherboard?
A: The motherboard uses an IT8518 embedded controller in a 128-pin LQFP package.
Q: What BIOS flash IC package is used?
A: The BIOS flash ROM is an 8-pin M-SOP package connected via SPI.
Q: What charging IC and architecture does this board use?
A: The charging circuit uses an OZ8602 IC with a BATT IN/CHARGER architecture.
Q: What is the memory configuration of this motherboard?
A: The board supports dual-channel DDR3 memory via two SO-DIMM slots.
| Brand | Shuttle Inc |
| Project Code | A14HV |
| Board Number | A14HV02 |
| Date | Tuesday, September 21, 2010 |
| CPU Platform | Sandy Bridge + Cougar Point |
| EC / KBC | IT8518 |
| EC/KBC Package | 128 Pin LQFP |
| Audio Codec | 92HD88B4 |
| BIOS / SPI Flash | Flash Rom 2 |
| BIOS Flash Package | 8 Pin M-SOP |
| Charging IC | OZ8602 |
| Charger Architecture | BATT IN/CHARGER |
| Power IC(s) | ISL62881, OZ8116, OZ815, OZ8291, OZ8033, FP6137, APL5315, APL1084, AM4826, AM4828 |
| RAM Type | DDR3 |
| LAN IC | JMC251 |
| HDMI Level Shifter | CH7318B |
| Card Reader IC | JMC251 |
