File Request panasonic cf-33 Intel Core i5-10310U
There is a problem with the backlighting.
I'm looking for the light signal coming from the motherboard.
Hello, we apologize for the delay. Due to staff illness and internet issues, response times were affected. We are taking steps to ensure this does not happen again. Thank you for your patience.
If you have an image but no backlight, the issue may be caused by the following:
  1. The LCD backlight circuit may be damaged and require replacement. This is a difficult repair, so replacing the entire display is recommended.
  2. The LCD flex cable may be faulty.
  3. Check the condition of the LVDS connector.
  4. Less likely: the motherboard section responsible for supplying backlight voltage to the LCD may be faulty.
