Schematic positivo bgh quanta sw6h rev1a schematic
BrandQuanta
Project CodeSW6H
Revision1A
DateMonday, November 22, 2010
CPU PlatformIntel Sandy (rPGA 989)
PCH / SouthbridgePlatform Controller Hub
EC / KBCIT8518/CX
Audio CodecALC269Q-VB6-GR
Charging ICOZ8681
Charger ArchitectureDis-charge IC (G5934)
Power IC(s)RT8207, RT8204, NCP6131S, NCP5911, RT8205C, ISL62872
RAM TypeDDRIII
RAM ArchitectureDDRIII-SODIMM2, DDRIII-SODIMM1
RAM Quantity / Slots2
Card Reader ICRTS5159
LAN ICAR8151
WiFi / WLAN ICWireless LAN/BT
The Quanta SW6H 1A motherboard is engineered for the Intel Sandy Bridge platform using an rPGA 989 socket supporting a 35W 2-core CPU. The platform controller hub connects via DMI, with DDRIII memory architecture supporting two DDRIII-SODIMM slots at 800/1066 MT/s. System management is handled by an IT8518/CX EC/KBC, while audio is provided by the Realtek ALC269Q-VB6-GR codec. Power delivery includes multiple regulators: RT8207 for DDR3, RT8204 for PCH +1.05V_VTT, NCP6131S and NCP5911 for CPU cores, RT8205C for 3/5V PCU, and ISL62872 for VCCSA. The charging subsystem uses an OZ8681 charger IC with a G5934 discharge IC. Connectivity features an AR8151 LAN controller, a RTS5159 card reader, and wireless LAN/BT support via Mini PCI-E.
A: The IT8518/CX is used as the embedded controller.
A: The OZ8681 is the charger IC, paired with a G5934 discharge IC.
A: The Realtek ALC269Q-VB6-GR is the audio codec.
A: The Atheros AR8151 is the LAN controller.
  • Positivo BGH=Quanta SW6H Rev1A.pdf
