positivo master n20i shuttle nh14cu rev b
The Shuttle Inc NH14CU motherboard is built on the Ivy Bridge processor platform with a Panther Point PCH, documented on January 17, 2013. The system utilizes an IT8518 embedded controller in a 128-pin LQFP package and an ALC269Q audio codec. BIOS storage is provided by a Flash Rom 2 in an 8-pin M-SOP package. Power management is handled by a suite of ICs including OZ8293, OZ8153, OZ80116, OZ8033, OZ8013, FP6137, APL5930, and RT8411, with battery charging managed by the OZ8602. Memory architecture supports dual-channel DDR3 across two SODIMM slots. The board integrates a JMC251 card reader controller and an RT8411 Gigabit LAN controller, with wireless connectivity via a Mini Card slot.
Q: What EC/KBC is used on the NH14CU motherboard?
A: The NH14CU uses an IT8518 embedded controller in a 128-pin LQFP package.
Q: What is the BIOS flash package type on this motherboard?
A: The BIOS flash is a Flash Rom 2 in an 8-pin M-SOP package.
Q: What charging IC is used on the NH14CU?
A: The charging IC is the OZ8602, labeled as BATT IN/CHARGER(OZ8602).
Q: What is the memory architecture of the NH14CU?
A: The NH14CU supports dual-channel DDR3 memory across two SODIMM slots.
| Brand | Shuttle Inc |
| Model | NH14CU |
| Motherboard Manufacturer | Shuttle Inc |
| Project Code | NH14CU |
| Date | Thursday, January 17, 2013 |
| CPU Platform | Ivy Bridge (PROCESSOR) + Panther Point (PCH) |
| EC / KBC | IT8518 |
| EC/KBC Package | 128 Pin LQFP |
| Audio Codec | ALC269Q |
| BIOS / SPI Flash | Flash Rom 2 |
| BIOS Flash Package | 8 Pin M-SOP |
| Charging IC | OZ8602 |
| Charger Architecture | BATT IN/CHARGER(OZ8602) |
| Power IC(s) | OZ8293, OZ8153, OZ80116, OZ8033, OZ8013, FP6137, APL5930, RT8411 |
| RAM Type | DDR3 |
| RAM Architecture | Dual Channel DDR3 |
| Card Reader IC | JMC251 |
| LAN IC | RT8411(Giga) |
| WiFi / WLAN IC | Mini Card |
