quanta quanta rq7 docking rev-1a 1115 1
The Quanta RQ7 project, documented under the Custom document number and dated November 15, 2006, is a port replicator/docking station design. It features a Smart Charger Port architecture for battery charging and integrates a USB 2.0 Hub Controller for USB port interfacing. The design supports dual LAN connectivity with both 10/100 and 1G Ethernet interfaces. The board includes a docking connector for interfacing with a host system, providing connections for CRT, TV-Out, DVI, IEEE 1394, audio, serial, parallel, and PS/2 ports. The schematic revision is C2, with noted revisions for component additions and EMI improvements.
Q: What is the project code and manufacturer of this docking station?
A: The project code is RQ7, manufactured by Quanta Computer Inc.
Q: What charging architecture is used on this port replicator?
A: The design uses a Smart Charger Port architecture for battery charging.
Q: What LAN interfaces are supported by this docking station?
A: The design supports both 10/100 and 1G Ethernet LAN interfaces.
| Project Code | RQ7 |
| Document Number | Custom |
| Date | Wednesday, November 15, 2006 |
| Revision | C2 |
| Charger Architecture | Smart Charger Port |
| USB Hub IC | USB 2.0 Hub Controller |
