Samsung 305E4A BA41-01681A BA41-01818A_Petronas-15DE_MP1.2_GB0630 Schematic
The Samsung Petronas-15 (Project Code Petronas-D 15) is a Sabine Platform motherboard based on the AMD LLANO CPU platform with an AMD HUDSON M2 (A60M) chipset and FCH-Hudson M2 southbridge. The board number is BA41-01681A, revision PR1.0, dated 2011.05.17. Graphics are handled by a discrete Travis_L GPU with dedicated VRAM. System memory consists of dual-channel DDR3 across two SODIMM slots. The embedded controller is an SMSC MEC1310, and the audio codec is an ALC269Q. Networking is provided by a Realtek RTL8111E LAN IC and a Mini Card 1 (WLAN) slot. The charging IC is an AEMC2112, and the HDMI level shifter is an ANX3110. A 4-in-1 card reader is implemented via an AU6437 controller. The board includes a thermal sensor on SODIMM1 and uses a 32.768KHz crystal for the real-time clock and a 25MHz crystal for the FCH and LAN.
Q: What is the board number and revision for this Samsung Petronas-15 motherboard?
A: The board number is BA41-01681A, revision PR1.0.
A: The EC/KBC is an SMSC MEC1310.
A: The charging IC is an AEMC2112.
A: The audio codec is an ALC269Q.
A: The LAN IC is a Realtek RTL8111E.
| Brand | Samsung |
| Model | Petronas-15 |
| Motherboard Manufacturer | Samsung Electronics |
| Project Code | Petronas-D 15 |
| Board Number | BA41-01681A |
| Revision | PR1.0 |
| Date | 2011.05.17 |
| CPU Platform | LLANO |
| Platform Alias | SABINE PLATFORM |
| CPU Model | AMD HUDSON M2(A60M) |
| PCH / Southbridge | FCH-Hudson M2 |
| GPU Type | dGPU |
| Graphics Architecture | Travis_L |
| EC / KBC | SMSC MEC1310 |
| Audio Codec | ALC269Q |
| Charging IC | AEMC2112 |
| RAM Type | DDR3 |
| RAM Architecture | Dual channel |
| Card Reader IC | AU6437 |
| LAN IC | RTL8111E |
| WiFi / WLAN IC | Mini Card 1 (WLAN) |
| HDMI Level Shifter | ANX3110 |
| Thermal Sensor | Thermal Sensor on SODIMM1 |
| USB Hub IC | AU6437 |
