Samsung Houston 12 Schematic
This Samsung N11M-OP1/GE1 motherboard is based on the Calpella platform, featuring an Intel Arrandale SV PGA CPU paired with the Ibex Peak PCH. The board utilizes DDR3 SODIMM memory in a dual-channel configuration across two slots. Graphics are handled by an integrated MCP (Multi Chip Package) solution. The system management is controlled by an SMSC MEC1308 EC/KBC, while audio is provided by an ALC269 codec. Wired networking is managed by a Marvell 88E8040 LAN IC, and a GL823 controller handles the 3-in-1 card reader. The board includes a SmartBattery charging circuit and uses an EMC2112 thermal sensor. The SPI ROM serves as the BIOS flash storage. The board is identified by the project code Houston 12 PGA and the board number BA41-#####A, with a revision of 0.8.
Q: What EC/KBC is used on this Samsung N11M-OP1/GE1 motherboard?
A: The EC/KBC is an SMSC MEC1308.
A: The audio codec is an ALC269.
A: The LAN IC is a Marvell 88E8040.
Q: What card reader controller is used on this motherboard?
A: The card reader controller is a GL823.
| Brand | Samsung |
| Model | N11M-OP1/GE1 |
| Motherboard Manufacturer | Samsung Electronics |
| Project Code | Houston 12 PGA |
| Board Number | BA41-#####A |
| Revision | 0.8 |
| Date | June 01, 2010 19:24:55 PM |
| CPU Platform | Calpella Platform |
| CPU Model | Arrandale SV PGA |
| PCH / Southbridge | Ibex Peak (PCH) |
| GPU Type | MCP (Multi Chip Package) |
| EC / KBC | SMSC MEC1308 |
| Audio Codec | ALC269 |
| Charging IC | SmartBattery Charging Circuit |
| RAM Type | DDR3 SODIMM |
| RAM Architecture | Dual channel |
| RAM Quantity / Slots | 2 (SODIMM 0, SODIMM 1) |
| LAN IC | 88E8040 |
| Card Reader IC | GL823 |
| Thermal Sensor | EMC2112 |
