Samsung JONES_SUB BA41-02150A BA41-02151A BA41-02152A BA41-02153A Schematic
This Samsung sub-board, part of the Chief River Platform, is designed around an Intel Ivy Bridge BGA CPU paired with the Intel Panther Point PCH. The board carries multiple identifiers including BA41-02151A(NAN), BA41-02150A(GCE), BA41-02152A(ATSCN), and BA41-02153A(UNIMICRON), with a revision of 1.0 dated May 18, 2012. Graphics are handled by Intel HD Graphics, while system memory consists of DDR3 1600 configured as Channel A. The embedded controller and charging management are integrated into a single MCU (ANAPAS86701). Audio is provided by a Realtek ALC269Q codec. Connectivity includes a USB2514 USB hub, a GL823 card reader, and a BCM47511 WLAN/GPS module. The HDMI interface uses a PS8122 level shifter, and thermal monitoring is managed by an EMC2112 sensor. Power regulation is handled by an OMAPSS411 IC, and a TPM 1.2 module is present for security.
Q: What are the board numbers for this Samsung sub-board?
A: The board numbers are BA41-02151A(NAN), BA41-02150A(GCE), BA41-02152A(ATSCN), and BA41-02153A(UNIMICRON).
Q: What EC/KBC and charging controller is used?
A: The EC/KBC and charging controller are combined in a single MCU (ANAPAS86701).
Q: What audio codec is present on this board?
A: The audio codec is a Realtek ALC269Q.
Q: What USB hub IC is used?
A: The USB hub IC is a SMSC USB2514.
Q: What HDMI level shifter is used?
A: The HDMI level shifter is a PS8122.
| Brand | Samsung |
| Model | 1 |
| Motherboard Manufacturer | Samsung Electronics |
| Board Number | BA41-02151A(NAN) |
| Date | May 18, 2012 20:25:24 PM |
| CPU Platform | Chief River Platform |
| CPU Model | Ivy Bridge BGA |
| PCH / Southbridge | Intel Panther Point |
| GPU Type | Intel HD Graphics |
| EC / KBC | MCU(ANAPAS86701) |
| Audio Codec | ALC269Q |
| RAM Type | DDR 3 1600 |
| RAM Architecture | Channel A (Standard) |
| Card Reader IC | GL823 |
| USB Hub IC | USB2514 |
| WiFi / WLAN IC | BCM47511 |
| HDMI Level Shifter | PS8122 |
| Thermal Sensor | EMC2112 |
| Charging IC | MCU(ANAPAS86701) |
| Power IC(s) | OMAPSS411 |
| TPM | TPM 1.2 |
BA41-02151A(NAN)
Ivy Bridge BGA
CPU Model
Intel HD Graphics
MCU(ANAPAS86701)
/ ALC269Q
DDR 3 1600
GL823
USB2514
BCM47511
PS8122
EMC2112
MCU(ANAPAS86701)
OMAPSS411
BA41-02151A(NAN)
Ivy Bridge BGA
CPU Model
Intel HD Graphics
MCU(ANAPAS86701)
/ ALC269Q
DDR 3 1600
GL823
USB2514
BCM47511
PS8122
EMC2112
MCU(ANAPAS86701)
OMAPSS411
