Schematic samsung np-r410 ba41-00529a ba92-03859a aquil-so rev 1.0 schematic
BrandSamsung
ModelX06
Motherboard ManufacturerSamsung Electronics
Project CodeAquila-Sonoma
Board NumberBA41-00529A
Revision1.0
DateJune 25, 2005
CPU PlatformIntel Alviso + ICH6-M
CPU ModelDothan (w/533MHz) & Yonah
PCH / SouthbridgeICH6-M
GPU TypeInternal Graphics
Graphics ArchitectureAlviso-GM
EC / KBCMICOM
Audio CodecAD1981B
BIOS / SPI FlashFWH
BIOS Flash Exact Model82802AC
Charging ICR5C841
RAM TypeDDR II
RAM ArchitectureDual channel
RAM Quantity / Slots2
LAN ICBCM5788
WiFi / WLAN ICWireless LAN
Card Reader ICR5C841
USB Hub ICCK-410
Thermal SensorEMC6N300
The Samsung X06 motherboard, project code Aquila-Sonoma, board number BA41-00529A revision 1.0, is built on the Intel Alviso + ICH6-M platform supporting Dothan and Yonah processors. Graphics are handled by the Alviso-GM internal graphics controller. The system firmware is stored in an 82802AC FWH flash IC. Audio is managed by an AD1981B AC’97 codec. The board uses a MICOM EC/KBC controller. Memory architecture consists of dual-channel DDR II across two SODIMM slots. Networking is provided by a BCM5788 LAN controller and a separate Wireless LAN module. The R5C841 IC handles both CardBus and charging functions. Clock generation is managed by the CK-410 clock generator, and thermal monitoring is performed by the EMC6N300 sensor.
Q: What BIOS flash IC is used on this motherboard?
A: The motherboard uses an 82802AC FWH flash IC.
A: The board uses a MICOM EC/KBC controller.
A: The motherboard supports dual-channel DDR II memory across two SODIMM slots.
A: The audio codec is an AD1981B AC’97 codec.
  • Samsung_NP-R410=BA41-00529A_BA92-03859A_Aquil-So_Rev_1.0_DR-BIOS.COM.zip
